Lug Nut Torque Setting
Old Apr 15, 2009 | 02:35 PM
nix's Avatar
nix
.......what's the proper setting for these? I've been told between 80-90 ft. lbs, so I usually set it at 85; what is right?//nk
Old Apr 15, 2009 | 02:43 PM
risky business's Avatar
IRC Founder
i don't feel comfortable having mine at below 95. i usually put them at 100, then double check them the day after i tighten them
Old Apr 15, 2009 | 02:45 PM
CTrx8's Avatar
space for rent
108 is what was mazda most recently recommended.
Old Apr 15, 2009 | 02:52 PM
nuke0907's Avatar
Never Blend In
here's the TSB for this too in case you don't believe it.
Old Apr 15, 2009 | 02:58 PM
nix's Avatar
nix
Ouch; that's a 27% increase overwhat I thought it should be!//nk
Old Apr 15, 2009 | 03:10 PM
Atilla's Avatar
I am THAT guy
whew!
I had em' at a 100. Good to know
Old Apr 15, 2009 | 09:35 PM
rx8cited's Avatar
Senior Member
I've never heard the snapping noise mentioned in the TSB in 5 years, so I continue to use 88-118 N.m (65-87 ft-lb).
Old May 22, 2010 | 07:06 AM
ganseg's Avatar
Nature vs. Nurture
I had seen someone post the 108 and I didn't believe it. I have also read about people breaking lug bolts. Could the higher torque be the cause?
Old May 22, 2010 | 07:17 AM
bassy's Avatar
I've used 77-80 ft-lb with no problems.
Old May 22, 2010 | 07:49 AM
bse50's Avatar
#50
I use an air tool and don't care about the actual torque
Old May 22, 2010 | 08:28 AM
G-ReX's Avatar
A Torque-Free Zone
I routinely do 105-110 (analog torque wrench) with no problems. I re-torque regularly for track & autocross.
Old May 22, 2010 | 09:47 AM
SARRAS's Avatar
Sydney, Australia
Lug bolts usually break because of binding metal to metal contact in the threads. Use something like Nickle anti-seize sparingly on the threads, or even plain old grease - again use sparingly. ONLY on the threads, don't get it between the end of the lugnut and the wheel.
Old May 22, 2010 | 11:24 AM
Huey52's Avatar
Registered Zoom Zoomer
108 Ft lbs. That's what the current TSB cites. 'been discussed plenty before.... as everything else 'round here.
Old May 22, 2010 | 01:53 PM
CIN3RGY's Avatar
I've always used 88 ft lbs. With no problems but good to know that its supposed to be more than that.
Old May 22, 2010 | 03:06 PM
wcs's Avatar
wcs
no agenda
110 ft/lbs
Old May 22, 2010 | 03:14 PM
Galen Darkmoon's Avatar
I don't remember
There is one Master Rotary Mechanic at our dealer,everyone that knows takes their 8 to him. when I asked he responded 90 ftlb for the street 100 ftlb for the track. He sez the TSB rating is to high, I'll take his advice any day.
Old May 23, 2010 | 08:23 AM
Huey52's Avatar
^ Oh yeah, your local mechanic knows more than Mazda's design engineers.
Old May 23, 2010 | 10:21 AM
I don't remember
Actually yes,when it comes to keeping the car on the road. Toyota design engineers ring a bell?
Old May 25, 2010 | 06:51 AM
Huey52's Avatar
Enclosed (note lug torque cited @ 108 ft lbs.):
File Type: pdf
Old Nov 20, 2010 | 03:11 PM
jasonrxeight's Avatar
funny thing I was looking at my S2 manual it still says 65-87 ftlbs...
Old Nov 20, 2010 | 03:22 PM
DarkBrew's Avatar
Extraordinary Engineering
The TSB torque settings are intended for stock wheels with the snapping sound issue...
Otherwise you can use the original specs as they always were fine.
Old Nov 20, 2010 | 04:16 PM
lateralus's Avatar
Wow, thank you for bumping this thread..... I have been trying to diagnose a popping sound when I turn for the last 3 months.
Looks like all I needed was that TSB and a torque wrench...
Old Apr 23, 2011 | 10:51 AM
Shinka_68's Avatar
As the once RX8 owner, now A5 owner pointed out in the SB:
"Revised wheel torque specs should be used anytime wheels are removed from the vehicle (wheel rotations etc..)."
Old Apr 23, 2011 | 01:24 PM
kster's Avatar
Yup, I checked the 2009 service manual and it states 65 - 87 ft-lbs. I've been setting mine at 85 ft-lbs for street and track so I see no reason to change.
Old Apr 23, 2011 | 01:33 PM
hakuna matata!
Aye. My little cordless impact wrench is rated up to 200 ft/lbs. Couple of seconds of that and I call it a day. Then again I do have aftermarket lug nuts as well.
