Engine rev up problem.
Old Apr 12, 2009 | 04:55 PM
xplod's Avatar
I have just rebuilt my 2005 Rx8 engine (13b). After rebuilding it I started the car but the engine doesn’t rev up above 3-4k rpm and it just drowns in petrol. I checked the fuel injectors- they are ok. I dismounted the engine and totally disassembled it but everything is perfect. So I know that the problem I have isn’t from inside the engine. And that gets me to where I’m now.. the electronics.
There is no warning light for an engine problem from the car’s computer.
The engine is stock.
Please help.
Old Apr 12, 2009 | 04:57 PM
Did you recheck the coil placement? Right plugs? Wires routed properly?
Old Apr 12, 2009 | 09:28 PM
syntheticdarkness's Avatar
ThEy MaDe Me Do It
I agree with 9k, check that stuff, but don't forget to check the fuel lines and so on. It might even be the computer. Make sure that you don't have to do any special procedure when putting a new engine in also.
Old Apr 13, 2009 | 06:01 AM
xplod's Avatar
^ all that is checked.
the fuel lines are checked too.. they are ok.
I really think its the computer.. everything else is right where it should be.
Old Apr 14, 2009 | 02:24 AM
xplod's Avatar
Come on guys, give me a hint..
Has anyone else had this problem before ?
Old Apr 14, 2009 | 12:24 PM
teknics's Avatar
Certified Mazda Tech
reset your NVRAM and see if it helps at all, most likely wont since you rebuilt it and probably reused your old crank pulley/plate. other then that more info is needed, just cause the CEL isn't on doesnt mean codes may not be stored.
kevin.
Old Apr 14, 2009 | 03:00 PM
quazmosis's Avatar
Chode
It wouldn't be the cat would it? Are you by chance using an old cat that's clogged?
Old Apr 14, 2009 | 07:18 PM
teknics's Avatar
good call, definitely answer that q.
kevin.
Old Apr 15, 2009 | 12:49 PM
xplod's Avatar
hmm.. I haven't checked the cat.. so that's the first thing I'm going to do tomorrow. Thanks!
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
dbarber
Jul 25, 2015 01:34 PM
vssystemluba
Jul 19, 2015 04:16 PM
Belalnabi
Jul 17, 2015 07:48 PM
