Cleaning Racing beat REVi
Old Apr 11, 2009 | 05:02 PM
mazda13b's Avatar
Its been about a year since I had my REVi put in, I had a rotary shop do it for me. I understand that you should clean the filter with K&N cleaning kit? Do I have to take the intake out and clean it, or is it just opening the top and taking out the filter? Would anyone mind explaining how to do this?
Old Apr 11, 2009 | 06:22 PM
invasion08's Avatar
You have to take off the strut bar and remove the MAF pipe then unbolt the filter from the intake box and take it out. Send an email to Racing Beat and ask them to send you the info on cleaning the filter.
Old Apr 6, 2010 | 07:36 AM
RXeckless's Avatar
Rotorless
I was looking for the same info. so here's a PDF
File Type: pdf
Old Apr 6, 2010 | 07:43 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
After you do it the first time you will learn that you really don't have to take of the strut bar or anything else to get it out. It easier if you remove the entire accordion tube, and the MAF tube will have to come out for sure............but you can get the filter out without having to remove the accordion tube, you just need to be careful. If you look at the pdf file someone just gave you, you can see that they actually did remove the accordion tube itself, but there is just(and I mean just) enough room to get it out without having to do so, but it takes some strength. Also............there is a huge debate on whether or not to really oil the filter, so I would recommend that if you do, don't go overboard and lightly oil it.
Old Apr 6, 2010 | 09:23 AM
heyarnold69's Avatar
Rotary wanabee
don't forget to clean the maf as well.
Old Apr 6, 2010 | 07:04 PM
Jon316G's Avatar
Grasshopper
Go to Autozone and buy the K&N Recharge kit.
It'll have instructions with it too.
Old Apr 6, 2010 | 07:06 PM
don't over oil it.
your MAF will not like you. Other then that, these guys pretty much have this topic covered.
It's a very easy procedure, no sense in ever paying someone to do it for you
WranglerFan
Nov 5, 2017 09:35 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
20b-3rotor
Sep 2, 2015 08:54 AM
