ExoticSpeed Coilovers - Any reviews?
Old Apr 7, 2009 | 05:42 PM
byez's Avatar
Features:
  • Steel McPherson bracket, damper Construction
  • Aluminum A-ARM strut upper mount
  • mono Tube internal construction
  • 32 way adjustable dampers, compression and rebound combined
  • Ride Height adjustable via bracket/strut
  • Front & Rear Pillow ball upper mounts for increased steering feel and sharper cornering
  • Larger piston diameter for strut type front and rear damper in 50mm
  • Powder coated damper body with Zinc+ black chromium coated threaded section
  • Piston Rod made with polished steel and hardens material for the durability and reducing leaks in failed shocks
  • Piston Valve Consists of patented deflective disk valve stacks for precise performance.
  • Rod and Seals in high pressure inner rod guides seals ensure a perfect fit for consistent, fade-free damping and dependable performance
  • Spring rate: front 10kg/mm, rear 8kg/mm
Contents of Damper Kit:
  • Adjustable Shock Absorber × 4 Bump Rubber × 4
  • Main Spring × 4
  • Hook Spanner × 2
  • Upper mount × 4
  • Dust Cover × 4
  • Seat Lock × 12
32 levels damping force settings
  • 0-8: Recommend for street and comfort use
  • 9-16: Recommend for Rally, mountain road use
  • 17-32: Recommend for race track use
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
