Painted Wheels
Old Apr 5, 2009 | 02:56 PM
RockTown07's Avatar
2005 Mazda RX8 6 Speed
Painted Wheels
Took all day Friday to do this started at 2 P.M. and took my friend and I till 12:22 A.M. The paint is smooth to the touch and looks like a pro did it, but I only spent $60 =)
The process I used was as follows...
1. Wash wheels and dry
2. Sand with 600 grit sandpaper
3. Rinse and dry
4. Sand with a 1000 grit sand paper (this is so that you smooth out everything so you don't get little bumps here and there)
5. Rinse and dry
6. 3 Coats of primer
7. 3 Coats of black paint
8. 3 Coats of clear coat.
Also took the center emblems off and taped them up so that they would stick out more with a black back round.
Tell me what you guys think!
Old Apr 5, 2009 | 02:59 PM
Sik-Boy's Avatar
not a big fan of painted wheels thats arnt aftermarket its to mexican, But those Fukin changed my mine very very nice
Old Apr 5, 2009 | 03:16 PM
OP: should have painted the lugs
Old Apr 5, 2009 | 03:19 PM
05rex8's Avatar
sold the 8... :(
not bad, but you should have painted the inside of the wheel
at least you painted the center caps tho
oh and get the dent fixed on the rear quarter flare
Old Apr 5, 2009 | 03:20 PM
RockTown07's Avatar
I thought about doing that, but decided that with the chrome emblem the lug nuts would flow well with it.
Old Apr 5, 2009 | 03:22 PM
RockTown07's Avatar
Yea I know I need to get that fixed there are a few more along that one but its hard to seem them it is on my list of things to do.
Old Apr 5, 2009 | 04:53 PM
perks11's Avatar
HEADTURNER
looks nice. I like the lug nuts not pianted to match, i think it flows well with the center caps
Old Apr 5, 2009 | 04:54 PM
Kadavr's Avatar
RSTi 402hp @ 17psi :(
Looks good, I will be doing mine this week. How many did you use, to get 3 coats on each wheel?
Old Apr 5, 2009 | 06:00 PM
briann's Avatar
Looks great.
So you don't have to sand anymore between paint? like after you primer them and all that? Just apply the three paints?
Old Apr 5, 2009 | 07:33 PM
RockTown07's Avatar
I used 2 cans of primer, paint and clear coat.
Originally Posted by briann
Looks great.
Yes or else you will sand off what you just sprayed. Make sure you allow enough time for the coats to set I waited 30mins in between coats for the primer and 45 mins between coats for the paint then about an hour in between coats for the clear coat.
Old Apr 5, 2009 | 07:37 PM
05rex8's Avatar
sold the 8... :(
actually by wetsanding the primer with 600 grit before you apply color is how to do it
it will smooth out the primer so the paint and clear will lay out better....and also promote better adhesion
personally I take it a step further by applying an adhesion promotor/sealer after I wetsand the primer before color coat
as for waiting an hour between coats for clear...not true...usually 5-10 mins max. you want it to "melt" into each coat or else it will be dull...and possibly make the clear and paint etch underneath
I do this for a living, but hey, what do I know
Old Apr 5, 2009 | 07:41 PM
RockTown07's Avatar
Or you could do this word for word lol I just threw out what I had heard from others and a lil of my own
Old Apr 5, 2009 | 07:44 PM
briann's Avatar
Thanks for the clarification. lol
05rex8, can you PM the procedure of painting rims the way you would?
I want to do paint my Mazda3 rims
Old Apr 6, 2009 | 07:16 AM
Sik-Boy's Avatar
Did u take the tire off the rim? im guessing no since the pics are at ur yard
Old Apr 6, 2009 | 02:46 PM
RockTown07's Avatar
Yes I did take the wheels off and if you mean did I take the tire off no I kept those on just used cards around the lip of the rim to keep paint from hitting the tires. I did this at my buddy apartment the garage there was heated and nothing was flying around in the air to stick to the wheels. The pictures were taken two days after painting them when I took it home.
Old Apr 6, 2009 | 03:15 PM
tza0001's Avatar
Dum Spiro Spero
Well done! I am thinking to paint mine as well!
Old Apr 6, 2009 | 03:56 PM
kennychopra17's Avatar
looks good. Clean job
Old Apr 6, 2009 | 04:22 PM
nvrfalter's Avatar
tonybob failpants
ban him.
rocktown: looks really nice. i agree with rex- you probably shouldve done inside the wheel, but the outside looks beast with the lugs and the caps. black out those side markers and you'll be lookin nice and evil
Old Apr 6, 2009 | 05:31 PM
RockTown07's Avatar
Thanks! Good luck with yours!
Thank you!
Originally Posted by nvrfalter
ban him.
Thanks man and I was thinking about doing the inside but I figured it would get dirty anyways and this is just a little something to make the car stick out and clean up those horrid curb rashes. Later on I will get a proper set of wheels like some HRE's
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
GranTouTou
Sep 30, 2015 06:11 AM
GK1707
Sep 27, 2015 07:33 PM
