RX Guy
12-21-2003, 06:40 PM
I have just noticed my 8 hesitates during WOT at exactly 7500 rpm. I repeated test runs about a dozen times. Each time, I started with a rolling start at 1st gear, then into 2nd with WOT. As soon as it reached 7500 rpm, I felt a definitely "tug". I know the intake port opens at 7250 rpm, but this "tug" feels wrong.
I recalled there's a thread with similar topic. But if I recall correctly, the discussion was concerning loading condition other than WOT. What do you guys think? Any opinion would be greatly appreciated.
BTW. I have 1500 miles on the 8.
Smack
12-21-2003, 09:48 PM
WOT = Wide Open Throttle
Pedal to the metal :D
Rotary Nut
12-22-2003, 05:48 PM
Kinda sorta thoughta! Thanks
vaughnc
12-22-2003, 08:50 PM
boink
If it's consistent, have the dealership check it out.
mine suffers the opposite...it seems to push at or around that RPM...
RX-GR8
12-22-2003, 10:51 PM
mine too. still havent pinged it yet though.
rx8ntexas
12-22-2003, 10:54 PM
Mine too...I feel a push as well....feels good
RX Guy
12-23-2003, 10:10 AM
Sounds like I better get the 8 to the dealer. Thanks guys.
cruzdreamer
12-23-2003, 11:06 AM
I took mine in for a couple of big bucks or tugs whatever you call it......said my engine was fine and mentioned it can happen when it is damp out or the engine is cold. I haven't had the major bucking since but it does run rough if it is not fully warmed up.
RX Guy
12-23-2003, 05:17 PM
Thanks for the input cruzdreamer. When I discover the "tug", I had already traveled 50 miles on the freeway just prior. Although, humidity was high. It was on the verge of rainning. :confused:
