View Full Version : Point in getting stock rx8 tuned w/ AP?
SpeedGSXR 03-31-2009, 01:02 AM I was just wondering that due to the fact that Mazda Maniac has stated himself that he doesn't care about customer service whatsoever, I need to find a tuner if I want an updated map within 3 months of sending it out...:icon_no2:
So, my question to you guys is - are the gains so minimal (not power but efficiency) that it's not even worth getting tuned? My car is only getting 15mpg when I'm easy on the throttle, I use 93 oct and techron in every 4-5 fillups to make sure carbon gets cleaned out since I'm not in the 7-9k range very often. I just want to try to lean out the supposedly too rich stock fuel maps.
What do you think about my question?
shaunv74 03-31-2009, 01:06 AM I think your question can be answered by searching under coils instead of AP...:icon_no2:
Highway8 03-31-2009, 01:34 AM I have found MM's customer service to be just fine. He tells me he is going to do something and he has always followed through. Have you had any bad experiances with him? Yes he had some turbo parts issues, some e-mails were lost (sent to the wrong address by customers or not sent correctly) and once in a while people slip throught the cracks, but over all the people who now what to except (1-2, maybe 3 week turn around) they are happy customers.
The big problem is that people expect the "customer is always right" attitude from MM, but the problem is that the customer is not always right and MM is working for a lot less money then other people charge, so he does not have the time to give that extra customer service attention some people like. He is charging $700 (standard price) for the AP and you get free tunning. The next best deal is $150 or $200 for one time tunning, MM gives 6 months or more free. Bottem line, know what to expect, follow the directions and be happy with a quality tune.
Now in your case, if you expect to have you MPG improve, you may be disipointed with the results, no matter who you use. Assuming that you coils, wires, plugs, air filter, alignment and tire pressures are all up to par, then you would need a 5-10% increase in MPG to even notice an improvement. That is a lot to ask of tune. Should you get it done? I cant answer that question for you. I purchased the AP and have had my vehicle tunned because I track the car and wanted the extra HP, oil metering, removed cat CEL and the fans to come on earlier. If I just had a daily driver or weekend cruiser, well I might not have it done.
Oh, some people report that if you drop down to 91oct you get better MPG.
Easy_E1 03-31-2009, 02:09 AM I was just wondering that due to the fact that Mazda Maniac has stated himself that he doesn't care about customer service whatsoever, I need to find a tuner if I want an updated map within 3 months of sending it out...:icon_no2:
And where did this info come from?
Mazdamaniac cares about Customer Service. He doesn't care for customers who demand it when the issue is not his service but the customers own stupidity.
He has over 300 of these around the WORLD right now. i just dropped 5 at UPS this morning for him.
He must be doing something right.
He is very concise in his instructions and expects the consumer to be the same in their reply of information. Very simple exchange. In return you get tuning for FREE.
All the other vendors charge you additional money for tuning. Hundreds of dollars. And you don't know who does the tuning.
No one else offers this kind of customer service. Anywhere.
So you make the call.
AJ's Shinka 03-31-2009, 02:31 AM He was going to tune mine, but I am not where I want to be yet (modwise). But he still offered to do so regardless, so kudos to him.
From what I've learned, you want to run richer because running too lean is bad for your engine and your cat if you have one on. Around 13.2 AFR at WOT IIRC is optimum.
I have been running Cobb Stage 1 Map since I was mostly stock and it works just fine. I have a couple mods now and will be trying to get a full exhaust system soon, so I will need to get a tune sooner or later. :)
The Cobb AP comes with a Fuel Efficiency Map if that you can load to your car if that is your main concern.
Fluid Motorsports is offering tuning with a 48 hour turn around, I guess that is another option, I haven't heard too much about it though.
alz0rz 03-31-2009, 02:49 AM My experience was Mazdamaniac was perfect.
I filled out everything AS asked in the e-mail, attached ONLY what was asked for, and made sure I only needed to send 1 e-mail. I never waited more then 1 1/2 weeks for a new calibration. I got 4 calibrations from him, 3 of which were "performance" calibrations.
Is it really so hard to do what you are ASKED to do? That is and always has been the problem with peoples tunes being delayed.
And yes, I did feel the difference.
Flashwing 03-31-2009, 02:59 AM Great to see some of these comments! To the OP, yes getting the accessport tuned for your RX8 is a 100% good investment for your vehicle. The capabilities of the accessport go way beyond power increases and allow the RX8 to run better without the hold-backs of relying on Mazda's flashes.
Here's a short list of stuff you can expect. Increased OMP output to ensure proper lubrication, elimination of various check engine lights to guarentee passing emissions while allowing you to run midpipes or other upgrades without a CEL while maintaining critical CEL's, turn fans on sooner to prevent overheating, raise your idle speed for a smoother idle, increase rev limiter as well as a host of other stuff.
With his Custom Calibration Service, you simply send a series of data logs and he send you back a flash for your RX8. You then test the flash to see if any further tuning is needed. Then repeat the process until your satisfied or MazdaManiac informs you no further tuning is necessary.
Due to the large customer base and the need for specific information, a strict set of instructions are in place for customers. The better you follow the instructions the less likely you will have any problems.
As seen above, people who followed the process to a T got their calibrations quickly and without incident.
The AP is a must have for any RX8 owner, stock or otherwise. It's the best money you can spend on your car period.
alz0rz 03-31-2009, 03:15 AM I am selling my AP now due to my accident and the car being totaled.. but I will definitely be getting ANOTHER accessport for the 09s.
SpeedGSXR 03-31-2009, 09:00 AM Look here: This thread isn't about what your opinion is of MM or how much of a fanboy or bandwagon-er you are, this was about a simple question I asked about getting it tuned with a close to stock setup.
But, since you decided you needed to throw your own .02 in on a completely unrelated issue, fine. Here's the attitude that says "I don't care about my customers" -
I'd gladly give you that data if I were:
a) Unconcerned with privacy issues; and
b) Interested in the least bit with the outcome of that survey.
That is MM's response to having a survey done on a customer satisfaction by his own customers...
I'm not one of those customers who thinks they always are right, not at all. As I've stated from the start, I just want some basic communication, and if things are going to be delayed a week or two, would like to be notified so I don't think I'm being scammed when I send an email inquiring about what's going on and don't get anything back.
Hence the reason for my original question, since I'm not sure that I can't rely on him for a timely adjustment, is it worth getting tuned on a dyno by a pro? (and yes, I'm getting the BHR ignition setup as well, that's already in the works)
Please try to stay on topic.
robrecht 03-31-2009, 10:43 AM Look here: This thread isn't about what your opinion is of MM or how much of a fanboy or bandwagon-er you are, this was about a simple question I asked ...
Please try to stay on topic.You should know you didn't really ask a simple question. You asked a loaded question. Aside from the thinly veiled attack on MM, it's not a simple question. In the hands of a good tuner, you can expect to get 10-20 hp gains, perhaps on the high side o that range if you're deleting your cat and going for a more aggressive tune with leaner AFRs. Not sure how carefully some tuners monitor EGTs and whether or how much that might shorten engine life expectancy. Any one have lont-term data? The real question is not about the AP but rather about the tuner.
If your only interested in fuel economy, the AP will not be cost-effective.
DarthRX8 03-31-2009, 10:46 AM Look here: This thread isn't about what your opinion is of MM or how much of a fanboy or bandwagon-er you are, this was about a simple question I asked about getting it tuned with a close to stock setup.
If you cannot wait 3 to 4 weeks for a calibration then you should go somewhere else. Jeff is very reliable as a tuner and as a vendor and nobody knows more about tuning the 8 than him. My advise is if you can wait, stick with Jeff, your 8 will be much happier :). If you cannot go to a local performace shop or through another vendor (not many to choose from who have expierence)!
My opinion is biased because I have not dealt with any other tuner for my 8. When it comes to my 8 (it is my daily driver), I do not want to risk hurting it mechanically in any way. The wrong tune could potentially destroy your 8, which is why I only trust the best with mine.
Atilla 03-31-2009, 11:01 AM +1 w/Darth
If you go with another Tuner, be careful and make sure your tuner understands the software and your car. Running too rich or too lean may cause some serious damage to your car.
J03K1LLARX8 03-31-2009, 11:08 AM yeah dude MM is is highly respected around here. so yeah any bad thing you say about him is not going to get good feedback from people. MM has hooked up alot of members and gives nothing but good servise for alot less than you can find. so fyi dont bad mouth the guy that can tune up an 8 like no ones business! also stupid questions deserve stupid answers, right guys? do your home work before you post BS!
jmc23200 03-31-2009, 11:13 AM Go to another tuner, spend a few hundred dollars, see that it doesnt make a huge difference for you, and go back and ask for a "free" tune to improve the previous tune. You will be laughed at. That comment from MM doesn't say he doesnt care about his cusomers, it says he doesnt care about the survey. Obviously there are going to be some people who get pissy because it takes 3 weeks for 1 man to help you since he is helping/tuning for hundreds of other people. Where is the logic in that?
Buy the Cobb AP. It is $700 and it only makes your car better. You also get 6+ months of free tunes to improve your 8 so it can be the best possible. Ifyou go to a local tuner, you will spend a few hundred dollars for 1 tue. Then when you get the bhr ignition system, need to spend another few hundred on another tune. Then if you add any more mods, theres another tune and another few hundred $$$. Or, spend $700 upfront, add whatever mods you want, email MM, and he will do it for free.
Your money, your choice.
BTW, I'll buy your AP alzorz :)
zoom44 03-31-2009, 05:32 PM The wrong tune could potentially destroy your 8, which is why I only trust the best with mine.
nobody is going to give him n NA tune that will destroy his 8 . please step back from the abyss.
a good tune CAN increase your mileage. my flash from RB definitely improved my mileage. anyone that ever tuned their car from the beginning when there was only Maurice's Canzoomer e-manage box knows that a good tune can indeed get you better mileage.
get the 11.x and 12s tuned up to the 13s and you will be doing much better- but probably at the expense of cat longevity.
go RB or Go Cobb with the tunes that come with or get it tuned by a local Cobb tuner. those are all real viable options. Or go Hymee:)
SpeedGSXR 03-31-2009, 05:43 PM yeah dude MM is is highly respected around here. so yeah any bad thing you say about him is not going to get good feedback from people. MM has hooked up alot of members and gives nothing but good servise for alot less than you can find. so fyi dont bad mouth the guy that can tune up an 8 like no ones business! also stupid questions deserve stupid answers, right guys? do your home work before you post BS!
You're just an idiot...badmouthing translates to copying and pasting him saying he doesn't care about what his customers think...wow :banghead:
Anyway, to the rest of you who could avoid getting butt-hurt at what I've said in regards to my experiences w/ MM, thanks for the info.
To the remainder aka sarcastic fanboys and MM groupies who are practically on your knees sucking his **** on this forum - please take the blindfolds of your bias off and realize that just bc someone can tune an engine with a specific tuning tool well doesn't make them God or obsolve them from the responsibilities of running a business...they are going to catch some flack - when it comes, just accept it instead of trying to run around throwing excuses up.
dozer 03-31-2009, 05:45 PM :uhh: ibtl?
cjkim 03-31-2009, 05:46 PM You're just an idiot...badmouthing translates to copying and pasting him saying he doesn't care about what his customers think...wow :banghead:
im neither a fanboy or a hater, but i think youve taken this a little too far :icon_no2:
ibtl!
jmc23200 03-31-2009, 05:48 PM Or you and your 9 posts can do more research about the different tunes available, their pros/cons, dont post here asking for opinions when you arent ready to accept all of them since they are someone elses opinions, and not knock someone that you havent delt with yet. Apparently you are a very angry person and I didnt know you can suck dick over the internet or via email. Ive been missing out then :lol:
Atilla 03-31-2009, 05:52 PM yeah...
a little off the deep end. there was a reason why people were advocating MM's work. Though it may take more than a couple of weeks to get the maps you desire, for the most part - it's pretty much worth the wait. A lot of tuners are available true, but not as much with a reputation like MM's. Though not everybody likes the guy or appreciates his 'customer service' - the positive results from those who have received their maps is undeniable. If you find another tuner that's better and can deal with a similar stress load that he's taken on...please post details of him/her. I'm sure others would be glad to post some Q and A.
p.s. IBTL
treceb 03-31-2009, 06:07 PM contac rb. take ecu off car and ship to rb and wait for it to come back.
i think to avoid all these "fanboy" posts u shouldve asked if a cobb ap tune would increase mpg and leave mms name out of it. theres a few cobb dealers and tuners out there...
DarthRX8 03-31-2009, 06:16 PM nobody is going to give him n NA tune that will destroy his 8 . please step back from the abyss.
maybe. However, what I was trying to point out was that tuning was something that I knew nothing about when I was considering sending my ECU to RB or buying the AP from MM (I chose to buy the AP so that I wouldn't have to worry about MAzda reflashing my ECU and other reasons).
If you have no tuning experience it is nice to work with someone who has and can answer your questions along with ensuring your 8 has the best tune.
If you go with the RB reflash, an AP from COBB/ MM or any tuning unit it really doesn't matter, as long as the person doing the work knows what they are doing. The unit itself all comes down to personal preference.
This thread has begun to peg the I'm an idiot meter, that has senseless comments.:icon_no2:
DarthRX8 03-31-2009, 06:44 PM To the remainder aka sarcastic fanboys and MM groupies who are practically on your knees sucking his **** on this forum - please take the blindfolds of your bias off and realize that just bc someone can tune an engine with a specific tuning tool well doesn't make them God or obsolve them from the responsibilities of running a business...they are going to catch some flack - when it comes, just accept it instead of trying to run around throwing excuses up.
You wanted to know what your options were for leaning out your too rich tune in order to achieve better fuel efficiency. People have answered. It all comes down to who you trust and how much money you are willing to spend. If you take your AP to a local shop, hopefully they can tune your 8. However you are looking at an additional cost (200 or more dollars). If you have the money and the shop has the knowledge great, that is what worked for you!
If you don't want to hear peoples opinions then you are in the wrong place. Your comments mean nothing except you are impatient, senseless and want to have the perfect tune NOW! Good luck with that and please let all of us know when you find that individual and how much it costs!
RufusVonStorm 03-31-2009, 07:22 PM Flashwing answered this perfectly.
IF the question is "what's the point in buying an AP for a stock rx-8" there are a lot of good reasons: omp output, fans on sooner, higher redline, leaner mixture, af monitoring, etc etc etc
SpeedGSXR 03-31-2009, 11:10 PM If you don't want to hear peoples opinions then you are in the wrong place. Your comments mean nothing except you are impatient, senseless and want to have the perfect tune NOW! Good luck with that and please let all of us know when you find that individual and how much it costs!
Once again, there are topic titles for a reason, and if all you took away from my post was that I am impatient, you are still playing in the shallow end of the pool. Speaking of the shallow end of the pool - to whoever said I haven't dealt with Jeff yet, you're wrong, I've been dealing with him for the past month since I ordered an AP and just got it the other day, look in the MazdaManiac issues thread, you'll find all about the 'dealing' I've had with him and his lack of respect.
I know that we, as enthusiasts, have come to accept a lack of customer service as a given in the aftermarket performance market - but a complete lack of communication is what is unacceptable to me.
I took my turbo S2000 to Mase of Stage VI in Jacksonville,FL (Masetuning.com) and he was able to iron out the 'perfect' or at least perfect enough for me in a few hours for 200 bucks...went from making a mere 375whp to 453 and a much smoother curve. Point being: I arrived wanting a better tune that day - does that make me sensless? does that mean I wanted it in 10 minutes instead of 3 hours? No. It just means that I expect people to deliver what they advertise in the time in which they advertise to deliver in. God strike me dead and 'senseless' for actually holding ANYONE, (better yet a person running a business who I have invested my money into) to what they say...:uhh: :banghead:
If you can't see how ridiculous you're being in saying I'm sensless and have 0 patience, you guys really are a bunch of bandwagoning butt-hurt groupies, which is fine with me...I'll just watch ;)
Atilla 03-31-2009, 11:15 PM Finding a tuner for an s2k and finding a good tuner for rotaries isn't close to being the same. . .you can tell by the interest of most major aftermarket companies...
SpeedGSXR 03-31-2009, 11:16 PM Flashwing answered this perfectly.
The question was: "So, my question to you guys is - are the gains so minimal (not power (http://www.rx8club.com/showthread.php?p=2944971&posted=1#) but efficiency) that it's not even worth getting tuned?"
Efficiency gains are my main concern, and were the focus of my question, but it was all drowned out by the MM fan club attacking the reality that Jeff isn't timely and that I *gasp* would rather not wait a month for a tune turn around.
I know that there are lots of good reasons for buying an AP for a stock rx-8, which is why I did - I just wanted to know if there were any worthwhile efficiency gains (once again NOT talking just power) to be had in getting it tuned or if the changes were so minimal that it would be agreed upon by the majority that spending the usual amount of $ to get it tuned wasn't worth it.
But like I said, I think that the MM fan club will drown me out of my question, which is ok with me, I can just ask a different way to make all of them happy.
SpeedGSXR 03-31-2009, 11:18 PM Finding a tuner for an s2k and finding a good tuner for rotaries isn't close to being the same.
I never said it was. I was giving an example with tuning a car and what was reasonable to expect in terms of time.
Jedi54 03-31-2009, 11:30 PM http://i32.photobucket.com/albums/d37/Jedi54/intelligence.jpg
- maps do not take 3 months to get
- your poor fuel mileage is probably being caused by something else
how old are your plugs?
how many miles on your 8?
how long since you replaced the coils? OEM coils?
have you cleaned your air filter?
neXib 04-01-2009, 05:57 AM Do you feel a difference with a tune? Yes, but I can only speak for myself.
But your comments about MM is basically an answer to the question itself. The tunes take a long time to get because a lot of people aren't following the instructions and asking stupid questions and doing it wrong, and because he does other community related things and isn't getting rich off it. It has nothing to do with being fanboys, it has to do with accepting reality. Some vendors sell everything they can get their hands on for a quick buck (won't mention names) while some are dedicated to the car's wellbeing.
Would it be better if it happened in under 48 hours? Yes. But if you do your homework before buying you know what to expect, and that's why most of us are happy with the service. 90% of the questions to him seem to be in the first post and he probably gets them as pm's as well.
AK RAM 04-01-2009, 07:53 AM I absolutely think it can be worth it in the long run. I see the better benefit being in areas other than HP increase (since HP increase is so minimal without supporting mods), though that is a bonus. The better oil metering and lower fan temps alone can improve the longevity of your engine considerably. The slightly better mileage, raised idle RPM (no more idle vibration) and other small improvements add considerably to your overall happiness with the car. I would like to see the retail price drop about $200 though. The electronics do not cost that much to manufacturer. There is a large profit margin built in to each individual programmer considering what it is. I use to sell programmers for other markets, so yes, I know. If that profit margin is not there based on the retail price they charge, then they need to find another vendor to manufacture the product. The AP will need a competitor before that happens. The need for custom tuning for even basic cars needs to go away as well. Programmer manufacturers in other markets do this much better.
I just wish the service and the person were better than they are (my personal opinion). MM does not see this as he gets plenty of positive support from his regular crowd, but he is hurting his business. There are a lot of people that will not buy from him because of how he treats people and how he runs his business. This is coming from someone that has never met, talked with, or done business with him; I only know what I see here and that is the impression I am left with. This is probably a result of being a one-man-show, but it is a problem non-the-less. The company that figures this out and does it right will make a killing.
AJ's Shinka 04-01-2009, 08:23 AM I have had a good experience with it since I was running the AP on my stock RX8 with the built in Cobb Stage 1 map which gave me extra power without any noticeable mileage reduction. Also I have used the Gas Economy mode on 300 mile trips to L.A. and you get better mileage at the expense of a lil bit of power. Now that I have put a couple mods (Mazsport Ignition, and midpipe) on the 8 it seems to work very very well with them.
I referred you to Fluid Motorsports as an alternative tuning source, there are others but I cannot recall at the moment. Is this what you were looking for?
robrecht 04-01-2009, 09:04 AM Also I have used the Gas Economy mode on 300 mile trips to L.A. and you get better mileage at the expense of a lil bit of power. How much better? What's your best highway fuel economy?
jmc23200 04-01-2009, 09:08 AM Its not the electronic itself that makes the Cobb AP so expensive. It's the 6+ months of custom tuning that comes with the AP. You can usually buy an AP used for about $500. Spending $500 on a device that can substantially make your car run better and not knowing how to get the device to do so is pointless. That would be like buying an 09 RX8 MT, not knowing how to drive MT, and not being able to learn how to. The customized tunes from MM, although it may take a couple weeks, is worth the price.
If you go into the Cobb AP discussion thread, you can see that MM gets the same questions over and over and over and over. Think of it this way. Everyday you come on this site, how many times have you answered the question "Is frothy stuff on my dipstick ok?". Now, how many times have you bashed the OP for not reading or searching? MM is 1 man helping hundreds. He knocked out about 40 tunes in one night and emailed them back to people. The only people who have issues receiving their tunes arethe ones who do no follow the instructions to the T. Also, in the Cobb AP discussion thread, it clearly says it is taking 2-4 weeks to receive the AP. Not so sure why you are bitching about it.
RufusVonStorm 04-01-2009, 03:22 PM Once again, there are topic titles for a reason, and if all you took away from my post was that I am impatient, you are still playing in the shallow end of the pool. Speaking of the shallow end of the pool - to whoever said I haven't dealt with Jeff yet, you're wrong, I've been dealing with him for the past month since I ordered an AP and just got it the other day, look in the MazdaManiac issues thread, you'll find all about the 'dealing' I've had with him and his lack of respect.
Got it. Yeah if that's your expectation going in you're bound to be disappointed. There's slim pickins' out there for folks who really understand the nuances of tweaking the AP maps for the rx-8. If I had to come up with an analogy I'd say you picked an exotic custom Linux build (rx-8) when what you really wanted was windows server that everyone can work on (s2000). Most everyone on here is just grateful to finally have some kind of tuning solution available for this vehicle.
You're experience platform frustration, I recommended you return to your s2000.
I have an AP and decided not to go through MM. I've been using the Cobb tunes and am going to slowly make adjustments to it to increase the non-performance aspects of the tune (oil metering, CEL deletion, increased idle, etc.).
If you have a bone stock 8 (or at least a NA with a stock intake) then you'll probably be content with the Cobb Stage 1 which will give you some gains. Not as much as you will get from MM who can go a lot further in tuning then the default Cobb will go since he does his tune on a car-by-car basis.
But if you already bought the AP from MM then I think you're insane to not use his service. All he requires is that customers follow the rules he puts out there before you even buy it off him. Put aside whatever angst it causes you and have him tune your car. Don't do it for you, him, or anyone else - do it for your RX-8. It'll love you forever for it.
