View Full Version : Missfire
shodan 03-30-2009, 05:43 PM Hey,
I got CEL yesterday and today i went to autozone to check it.
So i have missfire in "cylinder" 2 :)
I'm going to order spark plugs, coils and cables this week.
Question is how long can i drive with that without any harm?
Jedi54 03-30-2009, 06:02 PM you should be fine with normal driving but you want to change everything out as soon as you can.
mpg will suffer as will the car's performance.
www.onlinemazdaparts.com has great prices on that stuff
invasion08 03-30-2009, 06:12 PM i like either
www.waynemazdafactoryparts.com or
www.finishlineperformance.com
Uncivilizedracer 03-30-2009, 07:00 PM When you start to shoot fire out the back , stop driving
http://www.youtube.com/watch?v=EiY59NeYUng
shazy 03-30-2009, 07:17 PM Don't try to get the parts from the dealer, as they might (really likely) screw you over in changing them.
syntheticdarkness 03-30-2009, 08:07 PM You shouldn't pay anymore then around $25 per plug, $30-$35 per coil, and wires just depend on what you want. I know my dealer wanted for the plugs around $40 something, but mazda beat the parts store by around $10 for the coils.
Advanced was around $45-$50 per coil, mazda was around $30-$35. Make sure if you were to get wires from the parts store that they are the right one, cause advanced insisted that the wires they tried to sell me were the right ones and they looked like they went on my honda crv.:icon_no2:
invasion08 03-30-2009, 08:36 PM coils from www.waynemazdafactoryparts.com are 25.33 each and the wires are 56.60
shodan 03-30-2009, 08:58 PM When you start to shoot fire out the back , stop driving
LOL its not that bad yet :)
I'll get everything from http://www.finishlineperformance.com
Razz1 03-30-2009, 10:40 PM Misfires are normal on this car.
If you think your going to get rid of it... your funny.
shodan 03-31-2009, 04:32 PM I was getting random misfires before but now the CEL is always on.
Hey its 2004 rx8 with original spark plugs :)
Even in my old junky car i changed them once a year :)
Jedi54 03-31-2009, 04:35 PM Misfires are normal on this car.
no misfires on my car.
Rhino8487 04-04-2009, 08:29 PM I noticed my car had a coolant light and CEL on the other day. I found and replaced a blown coolant hose. The car idled very rough and sounded like it was going to stall out. I took it to autozone for a code check. I got a misfire code and a intake valve code. The person at autozone told me the intake valve could be sticking because of dirt or sand. I was told I should put the car on the highway and open it up, and if that doesn'thelp and theI noticed my CEL was on the other day as well.use some carb cleaner on it. The father in law and I took the car on the highway for a spirited 30 mile round trip I folowed him to check for smoke or anything else comming from the tail pipe. The car ran fine with no further problems. My only issue is the CEL stays on, it doesn't blink or anything just constant on. Is there anyway to turn the CEL light off since the car is running fine? Oh yeah, the car has been sitting for about 5 months. Sorry for the novel, I just wanted to get the facts out.
Mazurfer 04-04-2009, 08:35 PM Take it back to Autozone, have them read the code again and tell us what it is.
They can/will then reset it it, but if the problem still exists, the CEL will come back on.
It comes on for a reason, even if you think it's running right, so go have it read, have them reset it, and then tell us what the code(s) was.
Oh......what's your year, mileage, etc? What kind of maintainance have you been doing and when?
Razz1 04-05-2009, 12:42 AM no misfires on my car.
Don't be stupid Jedi!
You have the Access Port which is tunned to run lean, so no misfires.
Plus you have after market coils.
Stop convoluting the problems with these Red Herrings.:rant:
What you said was just post whoring!:spank:
Shodan,
Plugs and coils are not a guareentee to get rid of misfires.
The car runs too rich from factory.
Just, re-set the ECU.
If it continues to happen on a regular basis then replace parts.
In the mean time keep re-setting the ECU
chancejat 04-05-2009, 12:48 AM misfires are normal if your coils are weak.....
Razz1 04-05-2009, 12:51 AM Let the problem repeat its self.
If its a continuous re-occurance then you have a problem.
I have nothing against a good tune up, but if you don't need it................
Rhino8487 04-05-2009, 04:08 AM Take it back to Autozone, have them read the code again and tell us what it is.
It's a 2004 6speed plain jane with no frills and it's got 62,681 miles. We have the oil changed every 3K miles and have major maintenance performed as scheduled. The only issue is the last oil change. I bought a SRT Challenger in Aug '08, and the wife stopped driving the RX-8 (her car) and started driving the ram again. So the RX-8 sit for months. From Aug to Jan we only drove it about six times so we didn't have the oil changed. The car sat through the summer dust storms and winter rains/frost here in Vegas. Thanks for the help.
Razz1 04-05-2009, 02:14 PM Re-set the ECU. Look at the stickies.
Jedi54 04-05-2009, 02:33 PM Don't be stupid Jedi!
Stupid is the guy who makes false assumptions... ;)
No I do not. I am running the OEM coils.
whose the one ranting? Take a look in the mirror Razz... :spank:
Oh, and continuously resetting the ECU won't fix the misfires. all you're doing is resetting the fuel trims in an attempt to mask the problem
If you want to cure the misfires, you need to address the issue at hand. Most likely culprits are coils, wires, or spark plugs.
shodan 04-05-2009, 07:05 PM I'm still getting it. Now just random misfire.
tried 3 times to cruse at 8k rpm. 2 times random misfire after 20sec and 3rd time no problems :P. I'm getting coils and rest of stuff on Tuesday. Well i already bought it so i might as well change it. 5 years on original spark plugs is kinda overkill i think :P
shodan 04-10-2009, 08:12 PM I've changed everything today. Car is running smooth and no problems with anything.
I just have 1 question.
Leading spark plugs look the same, but Trailing one of them is longer.
Both of them have "T" symbol and blue endings but one look exactly the same as Leading:Eyecrazy:
http://lh5.ggpht.com/_bCZ8atduGlY/Sd_g9l-nkjI/AAAAAAAAAk8/YA5iNuQ9srI/41RW8WN8RYL._SL500_AA280_.jpg
http://lh5.ggpht.com/_bCZ8atduGlY/Sd_g9mmvj9I/AAAAAAAAAlE/plJ7qbzkWNA/51UVFYmL8JL._SL500_AA280_.jpg
invasion08 04-10-2009, 08:43 PM On the trailing Plugs do they both say RE9BT?
Stock Plugs are
Leading- RE7CL
Trailing- RE9BT
shodan 04-10-2009, 11:01 PM Well i put them already in so hard to tell.
Both boxes were RE9B-T but only 1 of them looked like that:
Well car is running fine so i don't think it matters.
Old plugs were mixed on one side anyway :P
DOMINION 04-11-2009, 07:58 AM Hope this helps
Jon316G 04-11-2009, 08:11 AM Both boxes were RE9B-T but only 1 of them looked like that:
Are you saying that the plugs looked different but both were labeled RE9B-T?
:Eyecrazy: Meaning the leading and trailing plugs were reversed in the block?
DOMINION 04-11-2009, 08:40 AM ^Whaaaaaaat he needs to read the caution *see atachment*
shodan 04-11-2009, 10:53 AM ^Whaaaaaaat he needs to read the caution *see atachment*
Like I said. Marked blue with "T" i put on Trailing and white with "L" on Leading.
Both Trailing have same marking and blue endings but they don't look same.
Yes!
