Normal Brake Wear
Old Mar 26, 2009 | 05:10 PM
Punikin633's Avatar
Normal Brake Wear
Hello,
My car is at a service shop right now because my brakes are making noises for the past month. My car is at about 65K miles. I have changed my front brake pads once at around 30K miles. I have never touched the rear brakes. The shop just called me and informed me that I need new front brake and rotors. He said that the rear is fine and the pads have about 75% left. Is that normal? I know that the front brake do most of the work, and it is noticeable by the amount of brake dust on the wheels compared to the rear wheels. Basically, what I am asking is if it is common to have the rear brakes last that long. At this rate, the front pads will be changed about 4-5 times before the rear's first service. Also, is there a specific rotor size or type that I must get? I know that pads are pads, and as long as I get a premium one, I am fine. All I know is that the RX-8 has sport tuned brakes, but I don't know what that entails. Thanks.
Old Mar 26, 2009 | 05:32 PM
Old Rotor's Avatar
Yes this is common and their are different rotors for different RX-8's.
Old Mar 26, 2009 | 07:25 PM
refugeefrompistons's Avatar
I'm the exact opposite and am relatively low in the rear at 10k. Fronts are perfectly in line with normal usage.
RXFEVER
Aug 29, 2018 10:14 AM
TheRedRotor
Sep 12, 2015 07:42 AM
