Random Flashing CEL at High RPM's
Old Mar 26, 2009 | 08:39 AM
UniBroW's Avatar
Destroyer of Guilds!!!!
Few weeks ago I had gotten a Flashing CEL when I was getting on it a bit. Soon as I saw the flashing CEL I let off of her and drove her easy and it went away. I've since driven her hard without any problems. Last night I was cruising for awhile @ around 75mph then decided to get on her again. I started getting the Flashing CEL and slowing the car made it go away. I probably wasn't over 70mph when this was happening but had the rpms up there. I had just gotten an oil change earlier that day as well. Just paranoid and looking for answers. I have 99,500 miles on her and haven't ever had a problem and she runs like a dream. The only modification I have done aside from struts/springs is a Racing Beat cat-back exhaust. I've since brought her to redline and no issues. Anyone have a guess as to what the random flashing CEL is?
Old Mar 26, 2009 | 08:43 AM
jmc23200's Avatar
You need new coils. A Flashing CEL is a misfire. This usually only happens when in high rpms, but if they get bad enough, will happen all the time. It's about $140 for OEM and BHR sells an upgrade which I think is like 500. It takes 20 minutes to install the Coils yourself and is very easy. Just look up the DIY Ignition Coil Install
Old Mar 26, 2009 | 08:44 AM
UniBroW's Avatar
cheers! Thanks, I was hoping it was something simple.
Old Mar 26, 2009 | 09:04 AM
jmc23200's Avatar
I'm pretty sure thats all it is, but then again I am no expert. Besides, you have 99k on your car, they need to be replaced anyway
Flashing CEL does mean misfire though. Good Luck.
Old Mar 26, 2009 | 09:07 AM
UniBroW's Avatar
Thanks again. *sigh of relief* =)
Old Jan 16, 2010 | 04:21 AM
Leonardo Rosas's Avatar
partyboy007
hey guys i know this thread is old but same thing happened to me,high rpms and CEL flashing but i just changed the coils well the dealer did brand new set of coils and spark plugs ... so just wondering if anything else could be wrong or there's nothing to worry bout ??
thanks guys
Old Jan 16, 2010 | 06:23 AM
DarkBrew's Avatar
Extraordinary Engineering
thanks guys
Plug wires?
I added a set of Racing Beat wires when I changed my plugs and coils
No more flashing CEL
Old Jan 16, 2010 | 07:21 AM
It's almost certainly a misfire and even though the CEL doesn't stay illuminated under certain conditions it will still be logged on the PCM. However it certainly does not guarantee that parts are defective. Please don't start swapping parts out just because some numnut on teh intrawebz tells you to. It can just easily mean that you have a strong high compression engine. The first thong you should do is reset the eccentric shaft profile in the PCM using the brake pedal technique. A search will show you how to do it. Afterward you will need to let the PCM relearn itself for a while. If you continue to have the problem then parts need to be properly tested and then only replaced if proven defective.
Old May 6, 2010 | 06:23 AM
UniBroW's Avatar
my motor turned up shot, if in doubt and it's still under 100k miles have your dealer check it out. If I had done that I'd have a new motor, diagnosing it myself led to my car being a driveway warmer.
Old May 6, 2010 | 08:04 PM
YeepsRX8's Avatar
Yeep RX8
Dude, get your coils soon. Failing Coils can lead to a fried CAT...
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
DVerdeyen
Sep 13, 2015 11:19 AM
