View Full Version : Do you need the RP bolt and gasket to install RP cat??
Rena my Rx8
03-23-2009, 01:55 PM
as the title says, im finally installing the cat later on today and i bought the cat from someone and i dont know if it came with the bolt and gasket when i bought it. thanks guys.
Jedi54
03-23-2009, 01:56 PM
yeah, those gaskets shouldn't be reused. Best to put a fresh one on when installing the RP. (it's what I did)
also, check the welds on the heat shield around the cat. They're not the greatest and down the weld could break and cause excessive rattle.
Easy fix though, just have someone throw a quick spot weld on it or do it yourself. (muffler shops can probably do it for less then $20)
Rena my Rx8
03-23-2009, 02:02 PM
thanks. and the only place to get that gasket is the website huh??
Jedi54
Not sure if it's the only place, but one of the easist.
Rena my Rx8
03-23-2009, 02:19 PM
aww boooo i guess i can't put it on today then lol damnit!!
baysj
03-23-2009, 02:29 PM
yea and the bolts from the stock cat are welded to the cat so you would need new bolts too.
Rena my Rx8
03-23-2009, 02:49 PM
yeah when i meant gasket i meant bolts and gasket haha... thanks for the help guys... i guess i just gotta wait n do it right the first timee.. grrr i hate that!lol
Jedi54
03-23-2009, 02:55 PM
did you check those welds yet?
Rena my Rx8
03-23-2009, 04:52 PM
nah not yet. when i do i'll make sure to let you know.
Rena my Rx8
03-23-2009, 05:10 PM
I took a look at the welding.. n I didn't see anything wrong frm what I cud tell... but then again I'm not an expert on welding...
Rena my Rx8
03-23-2009, 05:13 PM
i looked at the weldings and i didnt see anything that i thought was wrong... then again im no welding expert
