Weight?
Old Mar 19, 2009 | 05:48 PM
White_Shadows's Avatar
Weight?
The more and more I play with the doors and the hood on my 8....How much weight benefit is there to going Carbon fiber??? Anyone have all the numbers?
My orginal intentions were
Hood
Trunk
Doors
Fenders
Bumpers
Was looking at carbon creations for everything, but I would need Seibon Doors. Does anyone have the weight differences for those compared to stock. Is it even worth it? I mean 2 or 3 pounds?? I'll take a **** before I get in my car.
Also how much does the oem pearlescent white paint weigh? Because if I stick with aluminium only problem is it's kinda weak. I hit a bee in the wind and I have a new dent. I'm considering LineX ing the car. It can be applied over the paint, but if I have 6 pounds of paint on the car (have no idea could be way off on weight) then it would be beneficial to pull the paint off and do it to dry aluminium.
Old Mar 19, 2009 | 06:08 PM
VS8's Avatar
VS8
4 Cylinder Rotary
there is a thread let me find it for u
Old Mar 19, 2009 | 06:09 PM
VS8's Avatar
VS8
4 Cylinder Rotary
how serious are you about weight reduction
Base RX8 / cloth seats / no sunroof / fully fueled - 2960lbs
Hi Power Engine Fully Dressed (Flywheel but no clutch) less Airbox - 267.5lb (per Racing Beat)
Short Block with no attachments per MazMart - 184.0lbs
Stock Wheels (18'') - 21.5lbs
Stock Tires (RE040 18") - 26lbs (some users have reported 28lbs...need to check)
Stock Small Battery - 21.1lbs
Stock Replacement Battery - 37lbs
Lug Nuts - 0.3lbs
Engine Cover - 2.3lbs
Battery Cover - 0.7lbs
Emergency Tire Kit - 4.8lbs
Washer Fluid Tank (full) - 1.43lbs
Car Jack with Case - 6lbs
Bumper Reinforcement - 15.6lbs
Front Seat (power/leather) - 55lbs
Front Seat (cloth/base) - 37.5lbs (including sliders and mounting equipment)
Stock Catback Exhaust - 38.6lbs
Stock Cat & Midpipe - 23.2lbs
Stock Exhaust Manifold (with O2 Sensor) - 17.6lbs
Stock Intake System - 13lbs
Full A/C System - 18lbs
Stock Power Plant Frame - TBD
Stock Aluminum Hood - 15lbs
Stock Front Brake Rotors - 18.5lbs each
Front Calipers and Pads - 13.0lbs each
Stock Rear Brake Rotors - 12.5lbs each
Rear Calipers and Pads - 9lbs each
OE Front Shock Assembly w/ spring - 11.5lbs
OE Rear Shock Assembly w/spring - 12.5lbs
Endlinks front each 7 oz
Front sway bar 6.3lbs
Fog lights 1.2lbs
Oil pan with bolts 4.7lbs
headlight washer with hose 1.75lbs
4 brake dust covers 2.4lbs
Strut Front Bar 4lb
Aftermarket Parts:
Mazda Speed Exhaust - 33lbs
RX8 Store Cat - 11.31lbs
Greddy oil pan with bolts 6 LBS 1 oz
Intercooler piping with BOV no silicone couplings 7 LBS 0 oz
Greddy catch can 1.75lb
Greddy air filter 2 LBS
Interceptor X-EMS 3 LBS
Intercooler 10.6lbs
Turbo header with bracket 20.3lbs
Turbo *Greddy * 12.5lbs
Front racing beat sway bar 9.4lbs
Racing beat endlinks EACH 11 oz
Greddy strut bar Front 4.6lbs
Couplings with metal straps 3 LBS 0 oz
Greddy Front Strut Bar 4.6lbs
Old Mar 19, 2009 | 06:30 PM
That is an awsome list (granted missed everything I was looking for) Very helpful as I will use those numbers at a later point. The car is mostly stock till I get it paid off / warranty comes off, just incase I need to economy dump the car or whatever loss of job that kinda crap. Carbon fiber doesn't really lower the value or void warranty's as apposed to pulling out the back seats and what not. (What is the weight on those?)
Old Mar 19, 2009 | 06:32 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i wouldnt think so
Old Mar 19, 2009 | 07:06 PM
Hoss's Avatar
Pulling the seats shouldnt void the warranty, I would look into those carbon fiber parts though, often times they wont save you weight...
Old Mar 28, 2009 | 12:47 PM
Would or would not? Thats the thing we are alluminum. I would assume the savings are minimal as apposed to steel cars.
Nobody has weight on the paint though? Somebody has to work for a body shop lol. Whats a bucket of paint weight and how many does it take?
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Ian_D
Rotary Swaps
26
Jan 21, 2017 02:23 PM
hufflepuff
May 30, 2016 10:45 AM
