NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
I need someones help! - Car not starting up!
Old Mar 19, 2009 | 09:40 AM
KimRene's Avatar
Kim Rene
Unhappy I need someones help! - Car not starting up!
Hi All,
Here is my issue..... I am at work yesterday and as I was leaving my car doesnt start. I do have a weak battery and I had one of the guys here at the office try and jump start me and nothing. I am thinking that it possibly could be flooded?
So I left my car here over night in case it was flooded to see if it could dry out over night. I just got to work 2 hours ago and the damn thing is still not starting. I read to try to "dechoking procedure" meaning doing this:
1. Depress and hold the accelerator pedal to the floor and crank the engine for 7-8 seconds. (This will clean out any unburned fuel from the combustion chamber).
Note: 8 seconds is a long crank time - count 1001, 1002, 1003 etc.
2. Release the ignition key to stop cranking and wait 3 seconds.
3. Release the accelerator pedal and start the engine.
I am trying to avoid getting it towed to Mazda and spending an arm and leg if I can fix it myself. But looks like that towing is whats going to happen.
If anyone has any other suggestions, please let me know ASAP. Any advice will help.
Thanks in advance,
~ Kim ~
Old Mar 19, 2009 | 09:43 AM
StealthTL's Avatar
Metatron
Check the tool tray in the trunk, see if you have a big 'eye bolt' in there.
This screws into the top corners of the front bumper mesh, and becomes your 'tow point' - get a strap/sling/rope through there and get a tow start from another car or a truck.
Just pull the car at ten mph or so, in second gear.
This WILL start it.
Good luck.
S
Old Mar 19, 2009 | 10:00 AM
KimRene's Avatar
Kim Rene
I have an automatic though. Do you think that it may still work that way?
Old Mar 19, 2009 | 10:02 AM
CTrx8's Avatar
space for rent
if it's flooded you should still be covered under warranty. it was extended to 8 yrs/100k miles i believe.
Old Mar 19, 2009 | 10:04 AM
Atilla's Avatar
I am THAT guy
No, it won't work if you're in second gear if your an A/T
Have you checked out the deflooding procedure in the DIY forum?
Old Mar 19, 2009 | 10:14 AM
KimRene's Avatar
Kim Rene
CT RX8 - I have an 05 AT touring and I did get a notice in the mail like a year ago about the 100K mile warranty. Flooding covers it you are saying?
Atilla - Yes I have tried the "dechoking procedure" and it didnt work. I do have a weak battery though. In like an hour when I take my lunch break, I am having one of the guys in the office try that procedure again. If not I am going to have to tow my car to Mazda.
~ Kim ~
Old Mar 19, 2009 | 10:51 AM
CTrx8's Avatar
space for rent
here you go:
http://www.finishlineperformance.com...5-08-1883f.pdf
Old Mar 20, 2009 | 07:59 AM
KimRene's Avatar
Kim Rene
Thank you all for your help and advice. I got my car towed yesterday and I am waiting for a reply from the dealer today. Will let you all know what the hell happened to my baby!
Old Mar 20, 2009 | 02:50 PM
KimRene's Avatar
Kim Rene
Originally Posted by CTrx8
If it wasnt for this CTrx8 I almost got screwed by the dealership today. Indeed my car was flooded and they tried to tell me that it was not covered under warranty and I had to call MNAO and bitch to them first and then when the dealership called me back they said that they didnt get this service bulletin.
Pass the word that if your car floods and its under 100K use this Service Bullettin and it will cover it and also here is the link to the original MNAO extended 100K warranty letter.
http://www.racingbeat.com/pdf/rx8warranty.pdf
Thank you all for you help again and CTrx8 thank you, you rock for having that bulletin!
Last edited by KimRene; Mar 20, 2009 at 02:51 PM. Reason: signature showed 2 times
Old Mar 20, 2009 | 02:52 PM
Im_DANomite's Avatar
I love GOOOLD
nice, way to stick it to them...punk bitches.
rotaryspeed's Avatar
to avoid flooding you should be revving your engine to 2500 to 3000 rpm's for 2 to 3 seconds before turning off your ignition. this will burn off the unused fuel in the engine.
Old Mar 20, 2009 | 02:53 PM
Atilla's Avatar
I am THAT guy
Glad everything worked out KimRene.
Old Mar 20, 2009 | 02:59 PM
CTrx8's Avatar
space for rent
that's what we're all here for so i'm glad you were able to find the help you needed.
Old Mar 20, 2009 | 03:14 PM
dmc27's Avatar
doin' the bull dance
well, that and our love of pictures of 8s. some with Kim Rene would be nice. hint hint
Old Mar 20, 2009 | 03:40 PM
Shaftski's Avatar
What was the dealership? Just curious.
Not buying their excuse that they did not get that bulletin, they sound kinda shady so I want to avoid them if possible.
Old Mar 20, 2009 | 03:58 PM
kersh4w's Avatar
Hit & Run Magnet
agreed.
i bet they thought you didnt know anything and tried to take advantage of you. way to stick it to them. it's not like mazda doesnt reimburse them for their work.
Old Mar 22, 2009 | 07:19 PM
midlifer's Avatar
Where about in MA are you located? It's hard sometimes to fine a good dealership in any area. I go to Sentry in shrewsbury even though I did not buy my 8 there.
Bob
Old Mar 23, 2009 | 07:47 AM
KimRene's Avatar
Kim Rene
I know that they tried to take advantage of me but thankfully I am a smart young lady that does her research.
I am in the process of moving and I am waiting for it to get nicer out, then I will take a pic of my little "portuguese princess" aka my car and I will post it up for you all to see her.
Thanks again for all of your help again. You guys are awesome!!!
Old Mar 23, 2009 | 07:52 AM
KimRene's Avatar
Kim Rene
Bob
I live in Plymouth. Not to far away from you. The Mazda dealership that I go to is the one in Raynham near Taunton on Rt.44. Called Metro Motor Group, its a multi dealership that sells Mazda, Ford and Kia vehicles.
I go to this one becuase its closest to where I live and its right near where I work too.
Old Mar 23, 2009 | 04:31 PM
Descent's Avatar
I live in Norton (About 1/2 hour away I guess). I got my car at O'Hara Mazda in Fairhaven. Not sure how far that is from Plymouth, but the sales and service dept. there were always excellent to me. And they have one tech there who works on all rotaries, he's been working on them for 20+ years I think.
I remember when I was trying to buy my 8, I went to that route 44 mazda. They weren't very nice people
Old Mar 23, 2009 | 05:31 PM
chrism's Avatar
Misfit Moderator TnC
had i seen this earlier i might have driven up to help...........so now back to the pics.....where are they?
Old Mar 24, 2009 | 07:59 AM
KimRene's Avatar
Kim Rene
Boys I hate my car!!! Yesterday when I left work, it started to buck on me.....at high and at low speeds. Its getting stuck between 2000 and 3000 RPM. I drive in alot of traffic and yesterday as I was driving on the highway and whenever my car slowed down and I tried to accelerate it again it was getting stuck, like I could feel the car jerk forward and back and it seemed like ir was trying to resist the acceleration. I would be going 80 one second then slowing down becuase people
Has this ever happened to anyone here before? Right now my car is at the dealership and I am not a happy camper. This car I swear is a frigin LEMON! I am sooooooo pissed!!!
Old Mar 24, 2009 | 08:04 AM
CTrx8's Avatar
space for rent
there are a few things that could be causing this - clogged cat, bad coils and/or plugs, bad compression, and i am sure i'm forgetting something. here's another TSB to look at:
http://www.finishlineperformance.com...4-08-1924g.pdf
EDIT: i should add, i am not mechanically inclined whatsoever so take my post with a grain of salt. i'm just reposting what i have read in the past
Old Mar 24, 2009 | 10:05 AM
lepichichi's Avatar
I LuV mY Rotary....
it sounds like a cat issue keep us posted!
Old Mar 24, 2009 | 11:36 AM
Atilla's Avatar
I am THAT guy
Chugging?? hmmmm - have you or the dealership checked the coils/spark plugs??
