View Full Version : mazdaspeed cold air
quillero20
03-17-2009, 09:22 AM
i just install the cold air intake on my car from mazdaspeed but the check engine light is on with 2 codes (PCM/P0300,RKEP0039) i need help please
Red Rex
03-17-2009, 09:26 AM
You probably have a vacuum leak. Make sure all of your lines are secure and ziptie or clamp down ones that feel loose. Get the codes read ASAP.
Razz1
03-17-2009, 02:50 PM
I believe this cell RKEP0039 has been determined to be nothing.
Search the ECU tunning threads.
P0300 is random misfire. One of the causes is a leak on the intake.
Recheck and tighten the install.
Also, clean the MAF.
laythor
03-17-2009, 03:22 PM
Cleaning the MAF should be something everyone does at least once a year.
quillero20
03-18-2009, 09:21 AM
thank to everyone who replay to my post, i'm going to check that about the leak and also cleaning the maf sensor again but also i have pulleys and i forgot to mentioned them before but i really don't think this is the problem i really think it could be the cold air so i'm going to check that, thank you
REV-N-HIGH
03-23-2009, 08:56 PM
I also installed a Mazda Speed cold air, I had to get it tuned in order for the light to go off.
teknics
03-23-2009, 09:05 PM
what code did you have?
kevin.
Jon316G
03-23-2009, 09:20 PM
Did you remember to cap the VFAD nipple on the intake manifold extension?
laythor
03-23-2009, 09:36 PM
tuned how?
kdparsons80
03-23-2009, 10:12 PM
I have the MS CAI i had a similar problem. I capped the wrong vacuum line. Make SURE that you got the right one on the manifold. The directions are a little vague on that step.
nycgps
03-23-2009, 11:12 PM
rofl ?
Tuned ?
My car must be smoking then. cuz I just install mine, and no CEL ever?
quillero20
03-24-2009, 10:37 AM
yea i took it to the techs and they said that my problem is the underdriven pulleys so i need to het my car tune..... so guys cold air intake if you don;t put it right like they said tap the wrong vacum or tip it'll get you the code...
teknics
03-24-2009, 12:44 PM
underdrive pulleys require tuning? thats wrong too.
if you changed your crank pulley do the NVRAM Reset procedure that may help.
a CAI and underdrive pulleys wont set off a CEL requiring a tune in almost any car i could think of.
kevin.
nycgps
03-24-2009, 03:40 PM
Unless the installer is an idiot. there is NO WAY that they can install the MS CAI wrong ...
So easy even caveman can do it ...
Pulley needs a tune ? ... hmm ... ok ... nope ...
teknics
03-24-2009, 10:01 PM
if you dont put the screen in you can get lean codes, had that happen after installing a motor, apparently when i took the CAI apart the screen turned sideways and wedged in the tube lol.
kevin.
quillero20
03-25-2009, 09:37 AM
don't know but i'm going to get the second opinion
