09 wheel color
Old Mar 16, 2009 | 09:46 AM
michaelsk8er's Avatar
09 wheel color
I need to know the color code for the 09 model rims. I have some curb rash I'd like to try and clean up. I found an old post that mentions Duplicolor TY 01602, Toyota "Lunar Mist Metallic" 1C8 is a perfect match. Is this only for the older model 8's as in all the posts I saw with pictures this looks more silver.
Old Mar 16, 2009 | 09:51 AM
Aipex8's Avatar
X e p i A
Your sig says you have "Shinka Edition rims". Are these the 5 spoke rims from the pre 09 models or are they the new 10 spoke rims? Maybe a pic of you rim would help.
Old Mar 16, 2009 | 10:57 AM
I am currently using the Shinka Edition rims, which are way more silver than the stock rims. I took the stock 09 rims off and still have them. They have some curb rash and they are the ones I want to repair. Here is a pic of them on the car. I can get a close-up if need be.
As you can see they aren't as silver/shiny as the Shinka rims. It appears to be a pretty standard color for OEM rims. I see this color, or least something close to it, on other cars like my old Accord.
Old Mar 16, 2009 | 12:06 PM
Aipex8's Avatar
X e p i A
I'm not 100% sure on this, but from what I've seen the standard 09 (non R3) rims like you have pictured are the same silver as the standard pre-09 (non Shinka) 5 spoke rims. I've seen posts that say Sunlight Silver is almost a perfect match, and the ones that you mentioned in the first post are most likely for the standard silver rims (which I assume will also work on your 09 rims).
Old Mar 16, 2009 | 12:18 PM
That is the info I needed. Thanks alot. I wasn't sure if the color I found was for a more silvery rim since I wasn't sure what the OEM RX8 rims looked like. I wasnt 100% sure.
Old Mar 16, 2009 | 08:50 PM
G-ReX's Avatar
A Torque-Free Zone
I've heard that Lightning Silver (UARC) was the old wheel color, at least. Scroll this link to the Mazda colors. The wheels are at the end of the Mazda list: http://www.sherwin-automotive.com/sh..._ColorBook.pdf
JimmyBlack
273
Feb 10, 2020 10:23 PM
Tsurugi
Sep 7, 2015 08:27 PM
