my tail lights ??
Old Mar 14, 2009 | 08:10 PM
zeldaax33's Avatar
my tail lights ??
hey why are my tail lights always foggy in the inside; like there moist and covered from the insidee. Sometimes the water drips down?
do i need new tail lights?
Old Mar 14, 2009 | 08:11 PM
nuke0907's Avatar
Never Blend In
no, you just need new gaskets.
dont drill holes in them. people will tell you to do it. it doesn't work.
Old Mar 14, 2009 | 08:12 PM
lurch519's Avatar
www.evoperform.com
yes, you need new taillights. if you are within warranty, you can get them replaced at the dealer
Old Mar 14, 2009 | 08:35 PM
shazy's Avatar
seriously, no offense even if you are 16, search! Your other threads can be found by doing a simple search. Seriously if you make a thread of a milky or some retarded substance that's on your dipstick, people will seriously start to kill you...
BTW, the milky substance is normal for this car so if anything tells you there is something wrong, ignore them because it's fine.
Old Mar 14, 2009 | 09:23 PM
j67345's Avatar
search and you shall find your answer
Old Mar 15, 2009 | 11:59 AM
Myardor's Avatar
If still under warranty then take it to a mazda dealer.
They will fix it by either replacing the gasket or the tail light. Most likely they will replace the gasket, less expensive.
They will remove the tail light, dry it out ( that will take some time), replace the gasket and the re install the tail light.
Go to http://www.finishlineperformance.com....php?pageid=11
http://www.finishlineperformance.com...05-09-2055.pdf
and print the second link ie pdf out the water in the tail light TSB.
Take it to the dealer so the dealer will know what you are talking about.
NOTE:
This bulletin supersedes the previous bulletin 09-014/07, issued 4/13/2007. The DESCRPITION, REPAIR
PROCEDURE, PART(S) INFORMATION and WARRANTY INFORMATION sections have been revised.
• Changes are noted below in Red beside the change bar.
Do not drill holes.
No need to search since you sound like a LMF BrotherHood member.( MemberShip currently closed to new members! ) Largest BrotherHood Club in the World!
Old Mar 15, 2009 | 04:01 PM
Red71Chevelle's Avatar
I just got my right rear replaced under warranty but the only way I could get it done under warranty was if there was standing water and their was so I am happy
Old Mar 15, 2009 | 04:06 PM
tubingchamp's Avatar
What mawd bug?
^^ I had that problem last night EH EH?
Old Mar 15, 2009 | 04:20 PM
rglbegl's Avatar
Baned
Searching thread titles only;
Here are 29 other threads about it.
I used 'condensation' as the search word
https://www.rx8club.com/search.php?searchid=4574606
If you use 'water in lights' as the search words, you get these 4
https://www.rx8club.com/search.php?searchid=4574617
If you just search for 'tail lights' you will get 85 threads, mostly about water in the tail lights.
https://www.rx8club.com/search.php?searchid=4574624
Old Mar 17, 2009 | 08:59 PM
mmats69's Avatar
93.5 octane
Old Mar 17, 2009 | 09:01 PM
What mawd bug?
Baha :D
cliffkemp
Dec 24, 2024 10:48 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
