4 spd to 6 spd
Old Mar 10, 2009 | 08:35 PM
winddude's Avatar
So Awsome, I am the STIG!
4 spd to 6 spd
I was wondering if anyone has done a swap for the 4 spd Auto (used '03-05) to the 6 spd auto ('06+)? I would do this jsut to have a greater selection of gear ratios and therefore better perfrmace. So the why is clear, but the how and the how much are the questions.
This is something I'd like to do down the road. I'm not sure where to start other then gathering ideas and price costs. Has anyone seen a 6 spd auto for sale?
Heres what I think i'll need. If you can think of anything else, or think I may be able to use existing parts let me know.
-6sdp auto tranny
-ECU from a 6sdp auto car
-steering colum for 6sdp paddles
It should be easier then swapping to a manual. Any thoughts or ideas?
And I don't care what Mr. Clarkson says they are not a stupid flappy paddle gear boxs! I think they're very usefull. But i do agree with a lot else TopGear does. PS. I am the stig.
Old Mar 10, 2009 | 08:41 PM
deadphoenix52's Avatar
meh.
-6sdp auto tranny
you'll also need the engine.
Old Mar 10, 2009 | 08:51 PM
winddude's Avatar
That doesn't make sense. Care to elaborate on why I would need the engine?
Old Mar 10, 2009 | 08:54 PM
Alucard's Avatar
RX8 Club OG
Engine
Trans
ECU
Gauge cluster (idk if the numbers go past 4 on the older models.., might just need a reprogram or maybe the ECU will fix it)
The steering wheel and paddles shouldn't need to be changed...
It would probably be pretty costly... you might be better off getting a 3 rotor if your looking for power
Old Mar 10, 2009 | 08:56 PM
nuke0907's Avatar
Never Blend In
not worth it. you should have bought a 6 port in the first place.
i think Tajahabo1 tried.
Old Mar 10, 2009 | 08:59 PM
expo1's Avatar
He's as bad as Can
Because the engine from a 4-speed is not the same as the one used in the 6-speed AT. You would spend thousands of dollars for no improvement in performance.
Old Mar 10, 2009 | 09:15 PM
winddude's Avatar
If cost wasn't an object I'd put in a three rotor, or be driving an Enzo. Maybe down the road.
I would still want to upgrade the trans to a 6spd auto If I put in a 3 rotor, to gain the additional gear ratios.
I bought the '04 4spd auto because of cost, and wanted the paddle shifters.
From what I understand the 4spd Auto and 6spd auto both produce around 212hp. But the 6 spd has two extra ports. Only the 6-speed manual "High Power" that produces more 228 -247. I might be wrong the facts are from Wikipedia.
Are there any posts from Tajahabo1 attempts, I did a search but it said invalid user.
Old Mar 10, 2009 | 09:20 PM
Alucard's Avatar
RX8 Club OG
I was using it as a reference... if your gonna spend that much money you might as well do a worthy upgrade.....
the 4 port autos have the 4spd trans and make 197hp
the 6 port autos have the 6spd trans and make 212hp
just adding the 6sp trans will not give you more hp... it might make the powerband different but it would not be worth doing unless you are getting a different motor
here is taj's user page
https://www.rx8club.com/members/tajabaho1-33221/
Old Mar 10, 2009 | 09:42 PM
winddude's Avatar
I know I won't gain any horsepower, thanks, lol. The powerband wouldn't change with the transmition. A 6spd closer ratio transmition would allow me to stay closer to peak of the power band, no matter what engine is used.
FYI, I was planning to turbo my existing engine, a three rotor would be great this might be something to plan for down the road.
And Alcurd you're probably right the paddle shifters won't need to be changed they should just be switches. And the gague cluster I have no idea... you could be right. Thanks.
I'll have to think about it more, and take a look for the parts.
Old Mar 10, 2009 | 09:44 PM
Alucard's Avatar
RX8 Club OG
yea def something too look into... might be a good upgrade for all of us down the road... also pay attention to Nukes turbo thread... he shows us that there is light at the end of the tunnel lol
Old Mar 11, 2009 | 12:33 AM
09Factor's Avatar
Original Turbo 'd Auto !!
what? my turbo thread is chopped liver?
To swap in a 6 speed tranny the ECU and TCM communicate to each other. So for it to work right you would need to swap the motor to a 6 port, the ECU, wiring harness, the TCM, the tranny, the Gauge cluster, and all of the odds and ends of mount brackets and such.
I looked into doing this and a turbo was way more cost effective,
Old Mar 11, 2009 | 01:35 AM
laulongfei's Avatar
laulongfei
I thought this question was answered before, I was the one who first raised this question. Oh well...
It must remind myself is not worth it to do swap 4sp to 6sp.
Old Mar 11, 2009 | 02:06 AM
all the info it here.
https://www.rx8club.com/series-i-specific-performance-mods-97/mt-swap-151684/
if you can do it yourself and have all the parts it might be worth it. for everyone else, not so much.
Old Mar 11, 2009 | 04:01 AM
alnielsen's Avatar
https://www.rx8club.com/showthread.php?t=151684
I think, in the end, it would end up being cheaper to trade-in your AT on a newer MT than to go through all that time & trouble.
Old Mar 11, 2009 | 04:25 AM
romycha1's Avatar
Wait... they make a 6speed AUTO? I thought they were all just 4speed.
Old Mar 11, 2009 | 09:43 AM
winddude's Avatar
Yea came out in 2006.
Old Mar 11, 2009 | 04:40 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
I am just beginning to realize how many people do not read what has already been discussed. I think that there are at least 4 threads on changing from the 4 port a/t to a 6port a/t and why it is not economical.
For the reading challenged among you, the 4 port 4 speed when coupled with FI is just fine. The tranny is strong and with the added power from the FI you never will miss what you don't have.
Old Mar 11, 2009 | 04:45 PM
09Factor's Avatar
have you been living under a rock? Sorry couldn't resist that.
Phil
it's amazing what boost can do, Tubo Or Zupercharred.
Old Mar 11, 2009 | 07:34 PM
romycha1's Avatar
Ehhh.. pretty much when it comes to the "auto stuff"... Since it doesn't apply to me, I rarely click on a thread that has something to do with it.
Old Sep 3, 2009 | 03:19 PM
bhop's Avatar
NO A/C :(
LMAO...... Ok, ok, now the thread can just die. I just wanted to say that.
Old Sep 4, 2009 | 07:36 AM
2SeeKU's Avatar
Aussie
I fail to see the advantages to the 6sp. With the 4, you make roughly the same power, but you are in gear for alot longer. I'd say spend that money on a turbo, you'd be MUCH happier.
Old Sep 4, 2009 | 07:44 AM
Phil's 8's Avatar
Or a supercharger..........
Old Sep 5, 2009 | 12:22 PM
bhop's Avatar
NO A/C :(
I've been watching this forum for some years now and there are just so many ways to go about FI for the 8
mdl0209
May 23, 2019 05:46 PM
fistofmeat
Oct 7, 2016 12:15 PM
Forevermore
Sep 20, 2015 01:04 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Mr.Durden
Aug 12, 2015 02:21 PM
