Rotary question
Old Mar 8, 2009 | 04:38 PM
atruerx8racer's Avatar
AJ- THE True Rotarian.
Question Rotary question
would it make any difference if you swap the rx8 rotor and put it in a rx7 motor?
Old Mar 8, 2009 | 04:41 PM
shazy's Avatar
Awesome Thread.
Old Mar 8, 2009 | 04:43 PM
robrecht's Avatar
Uh, yeah. Which RX-7 motor you talking about, anyway? Turbocharged?
kersh4w's Avatar
Hit & Run Magnet
he wants to put in the motor from an n/a fb rx7.
Old Mar 8, 2009 | 04:44 PM
shazy's Avatar
I think he wants to know if you could swap out the ROTOR in the rx-8 and put in a (rew?) engine.
Old Mar 8, 2009 | 04:45 PM
kersh4w's Avatar
Hit & Run Magnet
just one rotor?
Old Mar 8, 2009 | 06:02 PM
Sleepy-z's Avatar
Well the exhaust ports are completey different on the housings therefore the seals(side and apex) and springs strengths on the rotors are designed to handle different heats I would imagine....different metal types/sizes. Then again I haven't touched a rx7 motor outside of the brand new ones. Also the rotor bearings may not be able to slide on to the ecc. shaft(different shaft size maybe) small things that may be different and so on. I am sure I am forgeting other reasons it wont work but I am tired, toured DC all day and I am beat.
Old Mar 8, 2009 | 06:07 PM
robrecht's Avatar
Assuming you could make an older 13B (not 12A) rotor work in a newer 13B Renesis, I still don't understand why you would want to. Just to save money, maybe? The Renesis rotors are lighter weight, which is a good thing.
Old Mar 8, 2009 | 06:11 PM
shazy's Avatar
Not to mention the rx-8 and the rx-7 have different grooves of the rotor that has to go onto the eccentric shaft since they don't use the same one. Or are those parts interchangable.
Anyway, I really don't think it will work for all the above reasons that sleepy-z had said... Try asking someone on the forums who has done the 13b Rew conversion on the forums. I'm sure someone has done it.
Heheh, Im gonna beat you to the 200th post
Old Mar 8, 2009 | 08:42 PM
Originally Posted by kersh4w
just one rotor?
Yes jus 1 rotor from an renesis (rx8 engine), can i be able to swap into an rx7's 13brew engine?
Old Mar 8, 2009 | 08:45 PM
I'm not talkin about the whole motor of the Rx8, I'm jus wonderin if you can swap an rx8's (1 rotor) replacing a rotor of an Rx7's 13brew engine.
Old Mar 8, 2009 | 09:30 PM
robrecht's Avatar
Oh, now I understand. Probably only a few people here that can give you a definitive answer 'though. I would email/PM Paul at Mazmart, BDC, or rotary ressurection. Suspect there's more people that can give you an answer over at RX7Club. Good luck!
UHATEIT
Mar 31, 2019 05:31 PM
projectr13b
Mar 1, 2019 09:00 AM
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
GracefulShanks
Aug 18, 2015 11:40 AM
groll69
MW RX-8 Forum
Aug 17, 2015 04:21 PM
