DIY Question: Fixing the Engine Splash Shield
Old Mar 6, 2009 | 10:48 PM
Mitharan's Avatar
I'm from Seattle and the previous owner apparently didn't like to go slow on hills so the guard under the engine was so screwed up that there was no repairing it, and about 1/3 of it was missing. I bought new parts but half the stuff is riveted together onto other parts (namely the wheel well guards) so some of the clasps are there but I don't have a rivet gun and with some the original fastener is just not there.
I was wondering if anyone else has worked on this and figured out a good way of fastening it. I could just glue/epoxy it but I don't want to interfere with oil changes and any engine work I do.
Old Mar 8, 2009 | 08:23 AM
DeViLbOi's Avatar
The devil made me do it
The RX8 plastic parts are put together with plastic clips, not metal rivets. These clips come in two styles, one has a phillips head in the middle and requires a quarter turn to pull the center out about a 1/4" and the other is flat and you use a flat head screwdriver to pull it out the quarter inch. Once the center is out the quarter inch you can then pull the full clip out from the outer edge. Here is an example of one...
Old Mar 8, 2009 | 08:47 AM
Juansito's Avatar
Redlined
http://www.finishlineperformance.com...cat=302&page=1
Or wheel well fasteners here:
http://www.rx8strakes.com/index.asp?...ROD&ProdID=103
Old Mar 8, 2009 | 08:55 AM
DeViLbOi's Avatar
ty Juansito
Old Mar 8, 2009 | 09:03 AM
Juansito's Avatar
Redlined
Np just trying to help
Old Mar 8, 2009 | 11:41 AM
AAChaoshand's Avatar
Rotary Powered
Or you can go to auto zone...
Old Mar 9, 2009 | 08:06 AM
Mitharan's Avatar
I'm aware of some of those clips. Sadly not sure how well I can get them out though its nice to know where I can order the new ones. The old ones are so old I could get enough torque on the screw part and get anything on the back side holding the clip. However trust me there are 2 metal rivets on either side. Trying to take the old one out I had to drill out 2 of them. I think the sheet is still at my buddy's place I could take a picture of them for ya
Old Mar 9, 2009 | 08:15 AM
HeavyMetal699's Avatar
Mazmart sells them.
I bought a few of them but they fall out pretty easy. As soon as I get a chance I'm tapping and bolting the engine under cover on to the frame.
Old Mar 9, 2009 | 08:40 AM
staticlag's Avatar
The Professor
you can buy a rivet gun at autozone for like $10
Old Mar 9, 2009 | 09:05 AM
DeViLbOi's Avatar
The rivets tell me that someone knew they had a problem and tried to fix it themselves instead of replacing that sheet. Any chance your car is lowered?
Old Mar 9, 2009 | 09:06 AM
staticlag's Avatar
The Professor
Stock rx8 undertray is riveted in two places from the factory.
Old Mar 9, 2009 | 09:28 AM
DeViLbOi's Avatar
I was under there a little while back working on something and I remember no metal rivets.
Old Jun 23, 2013 | 09:02 PM
arvigovi's Avatar
Underbody tray - factory plastic rivets\fasteners
I recently had to replace the plastic rivets on my under-body - following some posts in this forum - and also because the plastic rivets (\fasteners) need to be matched to the hole sizes - I just ended up getting them from the Mazda dealership. I paid about $22 for 10 of them. The part number was BC1D-56-145 and they fit perfectly (pic attached). I have a 2006 6-Speed RX8.
Attached Thumbnails DIY Question: Fixing the Engine Splash Shield-img_20130623_2145291.jpg
vapor2
Nov 3, 2020 03:38 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
stickmantijuana
Jul 19, 2015 10:33 AM
Belalnabi
Jul 17, 2015 07:48 PM
