Those with VooDoo knobs - Spacing
Old Mar 3, 2009 | 03:22 PM
416to212's Avatar
Utopia Taco Bell
Those with VooDoo ***** - Spacing
To those of you running Voodoo shift *****; do you find that the **** sits too close to the shift boot? Have any of you come up with any unique and clean solutions to raise it up slightly?
Old Mar 3, 2009 | 04:26 PM
risky business's Avatar
IRC Founder
i think mine is perfect. perfect size, height, weight, shape, color. heck i even like the name! voodoo paino black shift ****.
Old Mar 3, 2009 | 04:40 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Possible Solutions: Raise **** OR lower shift boot.
1. Remove insulation from under the shift boot. Should allow the shift boot to go a little lower over the shifter.
or...
2. Remove stock shift boot and trim it. Removing material will reduce the amount that it pushes up into the ****.
or...
3. Buy a cheap ebay shift boot for 4 bucks and trim it (so you don't mess up the stock one).
or...
4. Not quite sure how to go about this, but I'm sure their is a way to put a spacer nut or something on before the voodoo which would allow the **** to sit higher and still be tight.
I'm sure someone else will have better ideas. Mine tend to be lazy solutions and not very well thought out.
Even though I went with the ebay boot and it does pretty well.
Old Mar 6, 2009 | 01:03 PM
hoss -05's Avatar
Lucky #33
My **** sits just a tad higher then i would like it to. +1 for going voodoo!
Old Jun 15, 2009 | 03:55 PM
416to212's Avatar
Utopia Taco Bell
I took car of my low Voodoo **** situation. I went to Home Depot and found some hard rubber washers in the plumbing section of the store. One small diameter to go over the shifter shaft and a slightly bigger one to go over the first washer and mate nicely with my Voodoo ****. Not it sits 1/4" higher and I don't rub my fingernails on the leather shift boot.
Old Jun 15, 2009 | 04:25 PM
Does anyone know what the warranty is on these *****. I'm starting to see spider cracks in mine. It looks like scratches but I don't wear jewelry or anything so it cant be that.
Old Jun 17, 2009 | 05:54 PM
hoss -05's Avatar
Lucky #33
I really dont know. I would contact Voodoo and see. They seem like a good company maybe they could work something out. I got mine in crinkle black so i dont think i will be seeing the same problem.
Old Jun 17, 2009 | 09:52 PM
Yeah I'm gonna take some pics and see whats up.
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RX8mzda
Oct 1, 2015 10:17 PM
Rote8
Sep 22, 2015 03:43 PM
Vedivan1
Sep 20, 2015 04:39 PM
