DIY Request: Front Bumper Detail.
Old Mar 3, 2009 | 02:55 PM
xdj_jdx's Avatar
Pew Pew
Looking to see if anyone has or knows of any good DIY guides for detailing my front bumper i want to get rid of the rock chips and such. Any links would be greatly appreciated. Thanks!
Old Mar 8, 2009 | 11:33 AM
edblor's Avatar
RX-8 Taker Arounder
I second this DIY!
There was a great write-up regarding a stone chip on the hood, but the bumper is plastic.
Anyone?
Old Apr 7, 2009 | 05:48 PM
xdj_jdx's Avatar
Pew Pew
bump.... anyone?
Old Apr 7, 2009 | 07:57 PM
teknics's Avatar
Certified Mazda Tech
here's all I can provide (this is like the ultra basics and simply some instructions)
FRONT BUMPER DISASSEMBLY/ASSEMBLY
1. To disassemble the front bumper, remove the following parts:
_a. Front fog lights (Vehicles with the front fog lights)
_b. Headlight cleaner hose (Vehicles with the headlight cleaner)
_c. Headlight cleaner nozzles (Vehicles with the headlight cleaner)
_d. Headlight cleaner actuator (Vehicles with the headlight cleaner)
2. Disassemble in the order indicated in the table.
(see attached)
1-Screw A
2-Airdam skirt
3-Bolt A
4-License plate holder
5-Fastener
6-Front bumper mesh
7-Bolt B
8-Set plate
9-Front bumper retainer No.1
10-Screw B
11-Screw C
12-Front fog light hole cover
13-Front bumper fascia
Preparation Instructions for PolyPropylene Bumpers (PP)
(see other attachment)
kevin.
Attached Thumbnails DIY Request: Front Bumper Detail.-frontbumperblowup.jpg   DIY Request: Front Bumper Detail.-frontbumperprep.jpg
Old Apr 9, 2009 | 09:44 AM
xdj_jdx's Avatar
Pew Pew
that helps thanks teknics!
Old Apr 9, 2009 | 11:42 AM
KyGeezer's Avatar
I worked on my front bumper yesterday with the front of the 8 up on ramps. I had a big bunch of chips and dents that were mostly a lot smaller than a pin head and a few that were a little bigger down low on the bumper. They were very noticeable when you were close to the car.
I'd seen this suggested someplace on the web a couple of months ago. A woman suggested using a small paint filled syringe and needle with a little touch up paint in it to fill scratches. She claimed it was ideal...you got paint into the scratch and no place else.
Ex-wife #2 was a nurse. Once in awhile she'd forget to empty her pockets after a shift and I collected several disposable syringes of various sizes and a variety of needles from her. Anyway, I tried the using a 2.5 cc syringe with a quarter cc of titanium gray paint in it. The disposable one inch needle was probably a 22 or 24 gauge needle and I filed off the sharp point.
I was surprised how well it worked after I found that I shouldn't press on the plunger and get a big drop on the end of the needle. When I put the tip of the needle into a tiny chip the paint would flow into it. It didn't fill the chip, but it coated it making it almost invisible...even with my nose 2 feet from the bumper. After 2 or 3 chips, I'd have to tap with a finger on the plunger to get the paint to flow again.
This really worked well and I'm very pleased with the result. I cleaned the needle and syringe by sucking some acetone into the syringe.
It would likely work better for scratches with a 1 cc syringe and 27 gauge needle that drug stores sell to diabetics.
Old Apr 9, 2009 | 11:47 AM
KyGeezer's Avatar
I worked on my front bumper yesterday with the front of the 8 up on ramps. I had a big bunch of chips that were mostly a lot smaller than a pin head and a few that were a little bigger down low on the bumper. They were very noticeable when you were close to the car.
Ex-wife #2 was a nurse. Once in awhile she'd forget to empty her pockets after a shift and I collected several disposable syringes of various sizes and a variety of needles from her. Anyway, I tried using a 2.5 cc syringe with a quarter cc of titanium gray paint in it. The disposable one inch needle was probably a 22 or 24 gauge needle and I filed off the sharp point.
Old Apr 9, 2009 | 11:54 AM
teknics's Avatar
very nice tip! seems so simple but i never would have thought of it.
kevin.
Old Apr 9, 2009 | 11:57 AM
I usually use toothpick to fill tiny chips or scratches(with touch up paint), this process takes painfully long cuz you will need at least 2-3 layers of paint.
Apply 1 layer ... let it dry ... apply another layer ... let it dry ... until its even or "above" the paint around it.
then I'll use some Ultra fine sandpaper (like 2500+) Plus Water to "smooth" it out. after that just wax it.
Takes time, but saves ya money.
Old Apr 9, 2009 | 12:41 PM
KyGeezer's Avatar
I had tried toothpicks too. But I found that it was extremely difficult to get the right amount of paint on the toothpick. It was usually too much or too little. It was also a terribly slow process and being the impatient type, I gave up.
Using a syringe was a much, much easier and quicker cosmetic fix.
Old Apr 9, 2009 | 02:18 PM
Hmm, I will have to jack a heroin addict and get some needles and try this.
Old Apr 9, 2009 | 03:20 PM
kersh4w's Avatar
Hit & Run Magnet
make sure you dont get AIDS!
Old Apr 9, 2009 | 03:31 PM
rXter's Avatar
I have heard good things about Dr. ColorChip product. http://drcolorchip.com/
(no affiliation). I am planning to use it on my other car this summer. I'll post results when I am finished.
As for my 8, best money I spent on the car was a clear bra. Did it right after delivery and 40K miles and 4 years later not a chip on it. I would highly recommend it to anyone with a new or nearly new car that they want to protect. I did the bumper, lights, mirrors, and about the 4 leading inches on the roof.
Old Apr 9, 2009 | 04:33 PM
KyGeezer's Avatar
If you drive up I35 to San Marcos, get on TX21, turn left on TX50 just before Bryan, turn right when you hit US79, get on TX43 in Henderson, turn left on US59 in Marshall, get on I30 in Texarkana, turn on to I40 in Little Rock, get on I55 north in West Memphis, get on I155 in Missouri which will become US51 in Tennessee, get on the Purchase Pkwy in South Fulton, head east on I24, get off in a few miles on the W.KY Pkwy., and head north when you get to the Green River Pkwy., you can be here in 14-16 hours if you have a good radar detector. I've done the thousand miles many times going back and forth to see a woman near Wimberley ( Z28, ~2,200RPM at 80 MPH and 26-27 miles/gal.). You could say I was _____whipped.
Bring cold Campechanas...preferably from the restaurant in the little Mexican mall near the Alamo. I'm dying for one.
I'll supply the tequila.
-Bill
Old Apr 9, 2009 | 06:06 PM
teknics's Avatar
+1 on clear bras, in more ways then one.
kevin.
Old Apr 10, 2009 | 09:16 AM
xdj_jdx's Avatar
Pew Pew
ill have to try using some of my old needles ..... but yea i dont know where i would get somthing like that. I will try the toothpick deal tho
Old Apr 26, 2009 | 08:41 AM
RXeckless's Avatar
Rotorless
I am planning to use Dr. ColorChip on my car this summer. I'll post results when I am finished.
+1
Old May 1, 2009 | 05:35 PM
Zepo.'s Avatar
Redlined Rotary = Sex
Just purchased this, i'll write a review after i get it.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
paporx8
Nov 5, 2015 07:20 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
