WTB AccessPort
Old Feb 24, 2009 | 08:41 AM
GaMEChld's Avatar
Registered Noob
WTB AccessPort
Looking for an AccessPort for my 2004 6 speed MT.
I just need it mostly to kill my CEL's, and the other small things it does. I am already using Int-X for my fuel management.
The AP must not have any alterations to the stock pcm fuel settings. This is strictly for non-fuel management related stuff.
It does not need to be still in the time frame for MM tuning, I am not tuning with it for the forseeable future.
PM me with offers. Shipping to NY 11743.
Old Feb 24, 2009 | 09:25 AM
heyarnold69's Avatar
Rotary wanabee
I'm pretty sure you can get your fuel maps transfered to the cobb
Old Feb 24, 2009 | 09:29 AM
GaMEChld's Avatar
Registered Noob
I am not setup for a MAF based management system at the moment. I need to use vacuum based maps of the Int-X until I make my setup MAF friendly.
Old Feb 24, 2009 | 01:12 PM
nuke0907's Avatar
Never Blend In
you should be able to get a code reader cheaper.
Old Feb 24, 2009 | 02:15 PM
MazdaManiac's Avatar
Plus, the AP will only turn off codes it is specifically programmed to turn off.
It isn't a "built-in" feature, so to speak.
Old Feb 24, 2009 | 04:02 PM
GaMEChld's Avatar
Registered Noob
Yeah, in all likelihood I'll probly end up getting it straight from you MM, that way it'll pretty much be gauranteed to do what I want. Just had to see if there were any good deals to be had. Will be ordering soon, if no favorable response presents itself.
Old Feb 24, 2009 | 04:12 PM
gamechild: if you just want it to clear codes and you still want to keep using the Int-X, why not get a Scanalyzer?
the AP rocks but if you just want to clear codes, sounds like an expensive solution.
Old Feb 24, 2009 | 08:48 PM
m4f1050's Avatar
Im sure he wants to keep them off. But if you get it from MM you might as well get it tuned for your car. If you want to go back to Int-X remember to put a stock map on ECU you can probably change Cobb's stock one to turn off CELs and lower fan temps (what I did.) When I went back to Int-X I had a MM tune on ECU but it would not boost, I put a stock Cobb map and it started to work, I'm sure MM can explain this better than me.
Old Feb 25, 2009 | 06:56 AM
GaMEChld's Avatar
Registered Noob
I keep saying, I can't use the AP for tuning until I can use my MAF for the neccessary readings. Unless MM tells me differently, that's what I have heard.
Also, I have a code reader that clear codes, but thats not the same as deleting the codes from the PCM. The car needs to be code free completely for X number of drive cycles and time to give no problems during NYS Emissions Inspection. If I throw a code every time I start the car, just because I clear it, it doesn't matter. Then again, that's only hear say, so maybe I should go see if I can pass with my code reader.
Old Feb 26, 2009 | 07:16 PM
GAMBEAN's Avatar
bi polar rotor loner
I'm in the same dilemma. (nys inspection) I have an int-x thats not currently installed. I need an inspection like RIGHT NOW. I'm past due.
Old Feb 28, 2009 | 06:34 AM
GaMEChld's Avatar
Registered Noob
Lol, past due? Mine was up in like September 08'. Let's have a contest, see how long we can go. What's the record?
Heheh, well anyway, we will need a valid real inspection done to get our next Registration Stickers. It's all computerized and knows we havent had an inspection.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Sheldon24
Sep 19, 2015 02:37 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
