Locating Speed sensor wiring
Old Feb 22, 2009 | 01:36 PM
Team_Mclaren's Avatar
LOL TRQ
I'm looking for the wire that sends speed signal to.. well anywhere cause im looking to tap into it to get the signal off of it. I know the RX8 uses the CAN bus and its a pain to extract anything out of it, but there has to be one right?
thanks
Old Feb 22, 2009 | 07:10 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
http://foxed.ca/rx7manual/2003mazdarx8/ Maybe????
Old Feb 22, 2009 | 07:47 PM
Jon316G's Avatar
Grasshopper
The issue is that each speed sensor (4 total) sends their information separately to the control module.
Old Feb 22, 2009 | 09:00 PM
zoom44's Avatar
its not a pain at all to get eh info from the can bus- you just need the right gear
Old Feb 23, 2009 | 12:26 AM
LOL TRQ
even if i just tap into one, that would give me the speed of the vehicle no?
found something else online:
04 MAZDA MAZDA
CRUISE CONTROL
250-1223
Control Lever: 250-3421,250-3742
Adapter: NA
VSS Wire: SMALL WIRE HARNESS THAT RUNS UNDER POWER BRAKE BOOSTER
VSS Wire Color: WHITE/BLACK
VSS Pulse: 18,000
VSS Tach Wire: NA IF MANUAL MUST USE CLUTCH SWITCH 250-4206
Tach Signal Wire Color: NA
Brake Switch Positive: GREEN/RED
Brake Switch Negative: GREEN
would tat work? anyone know where the cruise control harness is?
LOL TRQ
Im not using an obd-II reader, so need analog signals.
ironj221
36
Jan 20, 2026 08:28 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
PotatoCannon
Sep 6, 2015 11:48 AM
stickmantijuana
Jul 19, 2015 10:33 AM
