My exhaust dump
Old Feb 21, 2009 | 11:31 PM
dmak_el's Avatar
My exhaust dump
Long story short, lets see the pic.
http://img54.imageshack.us/img54/8014/20090207172.jpg
http://img54.imageshack.us/img54/2371/20090207173.jpg
http://img18.imageshack.us/img18/4488/20090221181.jpg
http://img19.imageshack.us/img19/7627/20090221182.jpg
I forgot to take a pic when it's all welded up and installed on the car, but it's a good fit.
btw, the dump goes back to the right side exhaust tip, it was my friend's idea and it seems to be pretty good and clean. The exhaust valve is connected to the same vacuum source as the vfad at the front, it's been tested, it will open right at 5500rpm, and close when get back down to around 5k rpm.
http://www.youtube.com/watch?v=llp2pKO_UNk
here is a video
Update pic with it on the car (don't mind the ugly welds or the spray paint.....or the slight exhaust leak, i will try to fix it later)
Old Feb 21, 2009 | 11:57 PM
jjc3925's Avatar
holy raspiness
Old Feb 22, 2009 | 12:07 AM
mikeschaefer's Avatar
I wanna rock! Rock!
i guess almost t-boning that SUV was funny...
as for the exhaust mod, that sounds like a lot of work for something that sounds like *** and improves performance very little
Old Feb 22, 2009 | 12:20 AM
dmak_el's Avatar
my friend was driving
that's how rotary sounds like anyway, but any opinion is well come, rather you like it or not.
I just like to try things out, at least i know i can do it, or make things rather then paying 600bux+ for an exhaust that's also dont' improve much performance....even it sounds like *** to some people...
Old Feb 22, 2009 | 12:22 AM
trustbuddy's Avatar
not true.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/different-kind-exhaust-modification-164090/
Old Feb 22, 2009 | 09:39 AM
I wanna rock! Rock!
Originally Posted by trustbuddy
what's not true?
Old Feb 22, 2009 | 09:57 AM
expo1's Avatar
He's as bad as Can
what's not true?
Trustbuddy also has an exhaust cutout and in the thread he linked to there is a dyno run that shows about a +10 HP gain. if you can live with the noise and attention its a cheap mod.
Old Feb 23, 2009 | 06:30 PM
dmak_el's Avatar
it's funny how after trustbuddy posted up dyno numbers, all the haters just kind of shut up....
Old Feb 23, 2009 | 06:42 PM
laythor's Avatar
I zoom therefore I am.
because the haters had nothing better to do then post about things they don't know anything about.
Old Feb 23, 2009 | 07:03 PM
Hoss's Avatar
I kinda dig it. Its like nitrous with a WOT switch, power when you need it, nothing else is changed when you dont.
Old Feb 26, 2009 | 12:49 PM
notorque's Avatar
I bid thee farewell
so its nice and quiet til 5500rpm? ....I like this idea, I have sr exhaust right now, but its still restrictive.......only problem is every honda will think i have vtec or some crap, you know how they sound, quiet till 5 or 6 grand then they sound like a rattle can on roids.
you did a good write up.
also to the OP, where did you get the materials for the valve and such?
Old Feb 26, 2009 | 09:20 PM
dmak_el's Avatar
I have no cat, so it sounds just like a stock exhaust with no cat when under 5500rpm. I just put a switch between the vacuum solenoid and the pcm, since the pcm controls the ground to the solenoid. pcm will ground the solenoid after 5500rpm. By having that switch, i can keep the vfad and the exhaust dump close for street/normal driving. Once i close the switch, the vfad and dump will open at 5500rpm by the pcm. There are no fault memory in pcm with that switch i installed.
all the materials i got from work. The valve was from a bmw 335 muffler. The piping size is 2.25" and there is no point going any bigger in my case, since the valve is about 2 to 2.25".
Old Feb 26, 2009 | 11:02 PM
risky business's Avatar
IRC Founder
very interesting idea. cool write up too
Old Feb 26, 2009 | 11:09 PM
romycha1's Avatar
I'd like to see someone do this with FI
Old Feb 26, 2009 | 11:19 PM
notorque's Avatar
I bid thee farewell
i got a 08 328 in the driveway.......hmmmmm...
*grabs sawzall*
but for real, what year 335, maybe I can grab one from a junk yard. I think this would respond nicely when the nitrous is going
Old Feb 26, 2009 | 11:33 PM
romycha1's Avatar
How about a DIY... Maybe I'll do this also.
So the 335's come with butterfly valve on the muffler? Is it for the same reason you did this?
Old Feb 27, 2009 | 12:25 AM
silverkillrx8's Avatar
you could also just put a cut out after the cat but then you would have raspiness galore....actually thinking about doin this to mine ...deff agree with posting DIY
Old Feb 28, 2009 | 05:02 PM
dmak_el's Avatar
All 335(E90, E92) comes with that valve, lot of other bmw models have a valve for the exhaust too, but i think the one on 335 is the biggest 2~2.25". I think it's more for sound and then performance. The valve is on the driver side exhaust tip, go check it out when u see a 335 next time.
Well, i just happen to have one of those valve, so i just want to see if i can make it work. and it seems to be working well. Only problem i m having is, since it's winter and have lot of snow here. I found sometimes after i park it outside for a while, when i start the car again the dump valve would be froze most likely due to all the snow melted on it from the last drive, but after about 2~3mins, once the exhaust heat up a bit, the valve works normal again. not really that big of a deal for me, but maybe i will make some kind of shield for it.....when i have time.
Old Feb 28, 2009 | 05:14 PM
dmak_el's Avatar
what kind of diy do you guys want? coz it's mostly welding and cutting. i will try to get some more pic next time i have the car up in the air
and then just run a long vacuum hose from the front to the valve on the exhaust.
Then to control the solenoid, when engine is running, one of the pin on the solenoid will have battery voltage(connector is only 2pins). The other wire goes from solenoid to pcm. The solenoid turns on when pcm apply ground which then turns on the vfad and in my case also my dump. All i did to keep the valve close is put a switch between the wire from the solenoid to pcm. When switch is open, the circuit is open so solenoid will not turn on.
I pick to put a switch on the ground wire, becoz it's safer since it's after the load (solenoid). So if my wiring ever broke, or shorted to ground, it's not going to burn the car down, just the solenoid wouldn't work right. since i have to run the wires from engine bay into the inside of the car.
I thought about putting relay in there, have 3 different switch positions, one position is just keep the valve always close at all time, one is let it function by the pcm(open after 5500rpm), one is just open all the time. But then it will be lot of wiring, and i wouldnt' get into it.
The easiest way to have the exhaust valve open all the time, is just unplug the vacuum hose. becoz vacuum keeps the valve close, without the vacuum, valve wont' close.
Old Feb 28, 2009 | 09:18 PM
onyx8's Avatar
Sounds like a two-stroke.
Old Mar 1, 2009 | 06:29 PM
dmak_el's Avatar
my friend says it sounds like a 2 stroke dirt bike on steroid
Old Mar 1, 2009 | 07:34 PM
Nice Job, don't listen to the haters.
Old Mar 3, 2009 | 11:21 PM
dmak_el's Avatar
Updated with new pic on my first post.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
