What is the healthiest compression for the 8?
Old Feb 21, 2009 | 06:13 PM
laulongfei's Avatar
laulongfei
Just wondering if I was going to do a compression check, what is the healthy #? 190psi? 200psi?
that way i know when i do need a engine rebuild. thanks
Old Feb 21, 2009 | 06:47 PM
risky business's Avatar
IRC Founder
Not sure, but please fix your sig.
My dog want to drive a 300+HP & 300+TQ RX8
Old Feb 21, 2009 | 07:11 PM
laulongfei's Avatar
laulongfei
Old Feb 22, 2009 | 09:46 AM
Race Roots's Avatar
Former Sponsor
Old Feb 22, 2009 | 07:28 PM
Charles R. Hill's Avatar
Owner of BHR
Originally Posted by Fluid Motorsports
10:1
Old Feb 22, 2009 | 08:55 PM
09Factor's Avatar
Original Turbo 'd Auto !!
10:1
try again. chamber pressure not compression ratio.
When I did mine in Oct it was 127 - 129 front and rear was about the same. It could have been higher, I don't exactly remember. this was on a warm motor that sat for 45 min after a drive. also AP increased injected oil.
and 7.2 kpa or 100 psi = borderline anything below this # = rebuild
Old Feb 22, 2009 | 09:24 PM
Flashwing's Avatar
3-wheeler
I would agree that around 125 - 130psi would be a healthy compression.
Old Feb 22, 2009 | 09:34 PM
Nemesis8's Avatar
Bigus Rotus
Page 01-10-7 Workshop Manual
Standard 830 kPa (120 PSI) @ 250 RPM
Minimum 680 kPa (98.6 PSI) @ 250 RPM
Standard Difference in Chambers Within 150 kPa (28 PSI)
Standard Difference in Rotors Within 100 kPa (14.5 PSI)
Old Feb 22, 2009 | 09:42 PM
laulongfei's Avatar
laulongfei
09Factor thanks for another useful infro! Do you think I should check my compression before turboing my car right?
Which aftermarket makes good rotary blade?
Old Feb 23, 2009 | 01:01 PM
09Factor's Avatar
You will atleast know what you started out with compressions wise.
As for good Apex seals (thats what I'm thining u meant) Dr. Ianetti has some really killer ceramic ones. Widely used in the raceing circut. There is another manufacture that makes semi-flexible ones. Don't remember the name. Someone here did post some info on them.
Old Feb 27, 2009 | 03:33 PM
laulongfei's Avatar
laulongfei
Can anyone help me find what website I can purchase a better aftermarket Apex seal, I research online and in this forum, I didn't find anything please help! thanks
Old Feb 27, 2009 | 03:41 PM
alnielsen's Avatar
There isn't one. Unless you want to pay several thousand dollars for "Dr. Ianetti has some really killer ceramic ones". The factory ones should suffice.
Old Feb 27, 2009 | 05:21 PM
laulongfei's Avatar
laulongfei
got it thanks!
gwailo
May 14, 2024 06:57 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
