what connects to this...
Old Feb 19, 2009 | 01:54 PM
alri0085's Avatar
i haven't been able to find the right picture to compare my car's engine bay to, so let me try this. i have a few things missing in the engine bay. if you see a plug that is not connected to anything let me know if you know where it goes. thanks
Attached Thumbnails what connects to this...-rx83.jpg   what connects to this...-rx82.jpg   what connects to this...-rx81.jpg   what connects to this...-rx84.jpg
Old Feb 19, 2009 | 02:08 PM
StealthTL's Avatar
Metatron
That green plug is not needed, it's a control for the stock airbox, which you don't have anymore.
Be sure that the little vacuum nipple that goes with it is capped off - it's behind and below the metal throttlebody, on the bottom of the black plastic upper intake manifold.
S
Old Feb 19, 2009 | 02:31 PM
alri0085's Avatar
S
thanks. how about this AC connector. i believe it's for the receiver dryer but i'm not 100% sure. it's between the air filter and the fuse box.
Old Feb 19, 2009 | 02:39 PM
Silver06's Avatar
Zoom Zoom....
Hi.
Just an observation....
It looks like you don't have the plastic cover for the fuse box (I see dust and crap on the relays).
Please find one. These cars start exhibiting strange symptoms when they have electrical issues.
Old Feb 19, 2009 | 02:41 PM
StealthTL's Avatar
Metatron
Looks like you got some parts missing there - your a/c is probably toast., but you knew that.
s
Old Feb 19, 2009 | 02:57 PM
alri0085's Avatar
will do, thanks.
Originally Posted by Silver06
Hi.
Old Feb 19, 2009 | 02:59 PM
alri0085's Avatar
s
the compressor works. the car was in a front driver's side collision. when they body shop fixed it they didn't replace all parts.
Old Feb 19, 2009 | 03:21 PM
G3tR3DDY2GR3DDY's Avatar
i see what happened..
the AC line you are talking about was bent by the body shop when reinstalling the radiator/condenser. It should be on the other side of the radiator fans underneath. You will need to get the ac recharged and maybe another line if that one is bent too bad.
The plugs next to it actually go to your headlight, they didnt connect it when they put it in i guess.
Otherwise you are good to go once you get the coolant tank plugged in on the other side. That plug is for the coolant level sensor
Old Feb 19, 2009 | 03:27 PM
Old Feb 20, 2009 | 02:49 AM
G3tR3DDY2GR3DDY
nice job..
btw, just got your voicemail today.. and no, i dont recall right now what you needed but i dont have it.
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
archon
Oct 1, 2015 06:08 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
