Footman
02-19-2009, 08:57 AM
What's a good NON-ADJUSTABLE shock to match the Eibach Pro kit lowering springs?
View Full Version : Shocks to match Eibach pro-kit Footman 02-19-2009, 08:57 AM What's a good NON-ADJUSTABLE shock to match the Eibach Pro kit lowering springs? swoope 02-20-2009, 04:00 AM bilstein hd. http://www.rx8club.com/showthread.php?t=112151 and if you go with the eibachs you might send me a pm. beers :beer: Footman 02-20-2009, 08:57 AM Swoope, I read that thread too, but the Photomonkey guy says he'll put them on and see and then no more info in the thread. Then somewhere else with a newer post date, the guy mentions how he doesn't like the Bilstein HD on his eibachs at all. He says the shock rod is too long (like stock OEM length), and the Bilstein HD is not designed for lowering springs. swoope 02-20-2009, 01:51 PM the car i ro rode in had the bilstein hd with racing beat springs. it is a very good setup. the owner from the other thread trackattic runs time trials with it.. finished second last year in nasa. my suggestion for you is if you do the eibachs, put a second rubber spring perch on the rear to raise it by 3/8" the rear is to low otherwise. as to the bilsteins not liking lowering springs. dont have an answer for that, the racing beat springs trackattic runs only lower .5" you might contact bilstein direct with your question. beers :beer: Footman 02-21-2009, 10:32 PM Does anyone have Mazdaspeed shocks with Eibach springs? mau 03-02-2009, 10:01 AM Hi, in Europe: Bilstein B8 Sprint http://www1.carparts-cat.com/webkat.asp?SID=0008723241477622018004&ROOT=1 Kafka 03-31-2009, 08:13 PM this one? http://www.bilstein.nl/bilstein/b8_sprint WTBRotary! 03-31-2009, 10:23 PM Why not just get adjustable Koni Yellows and dont adjust them?!?!? mau 04-01-2009, 03:19 AM this one? http://www.bilstein.nl/bilstein/b8_sprint Yes ! |
