Jack stands one side at a time. Is it safe?
Old Feb 16, 2009 | 11:39 PM
Footman's Avatar
Dodging those Corollas
I am planning to buy one of those jack stand /hydraulic jack kits from Canadian Tire.
Say I am only lifting the front end of the car. Is it safe to use the hydraulic jack on one side; put the jack stand; release the hydraulic jack and go to the other side and repeat?
Or should I use the hydraulic jack on one side, and use the spare-tire jack that came with the car on the other and try to do both of the jack stands at once?
Old Feb 16, 2009 | 11:53 PM
HWK11's Avatar
Lighting Yellow
what i did was jack up the right side, put jack stand on both sides and lower the jack.
StealthTL's Avatar
Metatron
Yes, jack one side, then place jackstand, jack other side, then second jackstand.
I like to lift just enough to place the stand on it's lowest level, then do the other side the same - then if you need more height, raise the jackstands the same way, two or three inches each side at a time.
I just got a screamin deal on a jack at Canuck tire - 3 ton, SpeedLift, for $59, half off!
The SpeedLift feature lifts the jack about 8" at a stroke if it's not loaded, very useful.
s
Old Feb 17, 2009 | 03:29 AM
DOMINION's Avatar
I don't buy Kool-Aid
^Yea thats what I do. Thats a dam good deal!!!
Old Feb 17, 2009 | 08:38 AM
prospectjtaz's Avatar
Just make sure you lift at the right points. Lift one side place jack, use the lowest setting in order to avoid wobbling.
Try not to kill yourself.
Old Feb 17, 2009 | 10:28 AM
Sanguine's Avatar
The Gods of Jacking with come after your family, friends and the pets of those family and friends if you manage to turn yourself into strawberry jam.
Old Feb 17, 2009 | 10:51 AM
Thief's Avatar
Reppin Lightning Yellow
Originally Posted by Sanguine
The Gods of Jacking....
Fap fap fap fap fap
Azki23
Jun 27, 2018 03:48 PM
Paul_Y
Sep 21, 2015 02:23 PM
blkswan
Sep 2, 2015 10:04 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
