Loss of Power
Old Feb 16, 2009 | 01:23 AM
VS8's Avatar
VS8
4 Cylinder Rotary
Loss of Power
I have 04 MT RX8 with 50k miles (this happened randomly-i drove 10 miles stopped car and was fine, then drove back 10 miles car was fine, and then next time i turned on car i had following problems)
-Barely revs past 7k then it stutters up to 8k at max
-Very slow revs going up to 7
-New spark plugs
-Oil Level Fine
-Coolant Level Fine
-Just put stock cat on
-Car starts up normally
What could be the problem?
Old Feb 16, 2009 | 01:59 AM
coils first.
plug wires not tight second.
cat, but you said you put that back on. confused about that.
fuel pump third.
Old Feb 16, 2009 | 02:03 AM
VS8's Avatar
VS8
4 Cylinder Rotary
i put cat back on after using turbo xs midpipe...just to see if possibility of a clogged cat
Old Feb 16, 2009 | 02:24 AM
you had the problem with the turbo xs midepipe? if so you can remove the cat midpipe from the problem..
Old Feb 16, 2009 | 02:25 AM
VS8's Avatar
VS8
4 Cylinder Rotary
no i had problem with midpipe (it was to loud) so i put on stock cat
Old Feb 16, 2009 | 02:30 AM
Benjamz's Avatar
Tony says, RX8s are GREAT
maybe the ecu made itself a learned file for the midpipe, and now with the cat on it has to relearn the new set-up. that is if the only thing changed was the cat. put back on the midpipe and see if it goes away. good luck.
Old Feb 16, 2009 | 02:31 AM
was the loss of power after you put the cat back on?
Old Feb 16, 2009 | 02:32 AM
VS8's Avatar
VS8
4 Cylinder Rotary
yea but a about 2 weeks afters
Old Feb 16, 2009 | 02:37 AM
put the mid pipe back in and see if it revs again.
you killed the cat..
Old Feb 16, 2009 | 04:59 AM
ILoveFI's Avatar
If its not the cat then I'm almost 100% sure its the coils.
Old Feb 16, 2009 | 09:15 AM
j67345's Avatar
Yeah, sounds like it might be plugs & coils time
Old Feb 16, 2009 | 09:43 AM
Sheehan's Avatar
Zoom Zoom
I would try coils too.
Old Feb 16, 2009 | 11:17 AM
greg985's Avatar
The 337
if you end up having bad plugs and coils you may have killed you cat aswell, so check that while your at it
Old Feb 16, 2009 | 03:25 PM
Renesis07's Avatar
Vtak just kicked in yo!!
def sounds like a clogged cat,
put the midpipe back on and if your car seems normal, you found your problem.
Old Feb 22, 2009 | 04:32 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i put the pipe n but now the car wont start...but the cat was clogged
Old Feb 22, 2009 | 06:45 PM
VS8's Avatar
VS8
4 Cylinder Rotary
any1
Old Feb 22, 2009 | 06:47 PM
-JsW-'s Avatar
so your car won't start...? is that the issue at hand here? the other issue was solved...being a clogged cat, correct?
Old Feb 22, 2009 | 06:55 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
It's probably flooded now. Try the deflood procedure in the manual.
If that doesn't work, you can push/pull start it. Be in 2nd with clutch in at about 18mph, then let the clutch out smoothly. If it starts, put clutch back in and go to neutral(don't let it stall). Stay like that a minute or two, then go take for a spirited drive. If you can't do that for some reason........
you can start pulling plugs, cleaning them, purging gas/oil out of the engine by pulling the fuel pump relay and cranking the car 10 seconds at at time, with 20 seconds rest in between, until all smoke and liquid doesn't come out of the plug holes. Then re-install plugs and crank it over. Once it catches, have someone plug in the fuel relay will quick. If it doesn't work....then start over. Oh yeah.......you better have a spare battery as this will kill a battery quickly.
Old Feb 22, 2009 | 07:16 PM
Renesis07's Avatar
^^^ Sounds like fun, Im lucky I havent flooded mine yet from the sounds of it
Old Feb 24, 2009 | 02:48 PM
VS8's Avatar
VS8
4 Cylinder Rotary
great success deflooding FTW
Old Feb 24, 2009 | 02:54 PM
tsxmidship's Avatar
so how does it drive now?
Old Feb 24, 2009 | 03:00 PM
Update.
Old Feb 24, 2009 | 03:24 PM
VS8's Avatar
VS8
4 Cylinder Rotary
drives fine...i had to put midpipe back on and its sooo loud
Old Feb 24, 2009 | 03:34 PM
SideOfBacon's Avatar
list it FS + oem trade.
Old Feb 24, 2009 | 06:19 PM
Mazurfer's Avatar
Glad you got it running! What was the method of choice......since there is at least 4 ways to attempt it?
I've never flooded mine, but I have deflooded an Automatic for someone.
