Car wont start: no cranking.
Old Feb 10, 2009 | 04:59 PM
CraigRX8's Avatar
CraigRX8
Ok where do i start, gerabox was off car for about 3 months, starter just handing. When i put everything to gether my main fuse had blown. I assume this is from changing the conenction at the top of alternator (i take its a live connection) anyway, so everything works except indicators and starter.
I plugged in a dash hwak and it came up with a UO155 code which is a communications code.
What should i be doing next: Some people have suggested battery low, but i doubt it very much, the lights arent dimming inside, or starter even trying to go. I can hear the relay clicking in the engine bay. Some people have suiggested starter solenoid is stuck and give it hit?
If its a sensor in the gearbox, clutch position etc can i by pass it?
Old Feb 10, 2009 | 05:13 PM
Silver06's Avatar
Zoom Zoom....
Since the problem includes BOTH your starter and indicators (turn signals), I would tend to suspect a power problem. Check all of the fuses (from the main fuse onwards). If no problems, then ignore the lack of turn signals.
EDIT: Please also have your battery on a charger. Verify you have +13 volts. You will kick yourself if you spend hours diagnosing and it turns out to be the battery.
There are two switches on the clutch pedal. The upper switch (hidden on the firewall side of the pedal arm) is the starter interlock switch. Continuity is when the clutch is depressed - so you can easily jump the switch with a wire / paperclip for testing purposes.
Old Feb 10, 2009 | 05:15 PM
CraigRX8's Avatar
CraigRX8
is that what the white and black connectors are for on the gearbox?
I also havent filled the gearbox with oil yet, does it have a sensor for this?
Old Feb 10, 2009 | 05:24 PM
Silver06's Avatar
Zoom Zoom....
On the M/T, the wiring harness has two connectors - one for the reverse lights sensor on your driver's side , and one for a 'neutral' switch. There is no fluid level sensor.
I wouldn't run the engine when there is no oil in the transmission. Especially if the transmission has not been lubricated for 3 months.
Edit: Just to clarify - the neutral switch is on the Driver's side for North American cars. (I'm assuming the O/P's car is RHD).
Old Feb 10, 2009 | 05:29 PM
CraigRX8's Avatar
CraigRX8
IT WAS ONLY TO START IT. I WAS A BIT WORRIED PCM HAS LOCKED ITSELF AS THE CODE COMING UP ON THE DASHHAWK. bTW the dash is also completely out of the car at the miniute
Old Feb 10, 2009 | 05:31 PM
hakuna matata!
start simple - check the battery and make sure its giving out the juice.
when my battery went completely dead my lights wouldn't dim either.. and the starter didn't even try.. all I heard was click click.
Old Feb 10, 2009 | 05:35 PM
CraigRX8's Avatar
CraigRX8
was the clicking the relay or the starter
Old Feb 10, 2009 | 05:37 PM
hakuna matata!
i turned the key and heard 1 click - that was it.
definitely not the starter.
Old Feb 10, 2009 | 05:39 PM
CraigRX8's Avatar
CraigRX8
yeh it could be battery i guess. i hope it is anyway :D
Old Feb 10, 2009 | 05:48 PM
Silver06's Avatar
Zoom Zoom....
Okay. This adds to it. I'm not sure if the CanBus system will allow the engine to run if there are components disconnected, such as the instrument cluster and the modules behind the glovebox.
You might want to ask someone who has done an engine swap for their experience.
Old Feb 10, 2009 | 05:54 PM
CraigRX8's Avatar
CraigRX8
ok, i have the instrument cluster, hooked up, thekeyless entry hooked up, but not the dsc etc, ill put it all back together again and try
Old Feb 11, 2009 | 05:22 PM
CraigRX8's Avatar
CraigRX8
new battery in tonight, how do i know if its an im mobiliser fault
Skyl3r
Dec 2, 2019 04:51 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
AussieGray
Jul 16, 2015 03:58 AM
