PRLegend
02-08-2009, 11:10 PM
I have and 04, Blk/Blk 6sp with 100K and just recently the clutch gave up. First it was a little loose on the pedal then it went to the floor. It happen at the Florida State Fairgrounds. Hit the brakes for a person to walk across and that was it. Could not put in gear after that. Its at the Mazda Dealership getting fixed. Wish me the best.
Jon316G
02-08-2009, 11:12 PM
Fluid low?
Makes me think so since you mentioned brakes also (clutch and brake share the same fluid).
Bunique
02-08-2009, 11:17 PM
what happened to me was it was a broken clutch pedal assembly....it's happened to alot of peeps. usually around 50k miles tho. there is a thread on it some where on here. best of luck.
JeRKy 8 Owner
02-08-2009, 11:27 PM
How much they charging you????
Bunique
02-08-2009, 11:29 PM
no charge.....it was covered under warranty I think.
Charles R. Hill
02-09-2009, 12:08 AM
That "loose" feel was the welds giving out on the pedal. They finally snapped on you.
Razz1
02-09-2009, 09:43 AM
Snap!
By the way... clutch and brakes use the same fluid, same reseviour
