identity disorder - rx8 thinks it has a cammed v8
Old Feb 7, 2009 | 02:50 PM
kersh4w's Avatar
Hit & Run Magnet
the title says it all.
it hunts for idle like no other. although it sounds pretty cool, like a very leanly tuned engine at the drag strips, it really bothers me, especially when it stalls out.
if you guys need a video, i can post it. but i'd like to hear your thoughts beforehand.
other pertinent info:
i uninstalled my custom (teamrx8) intake and i uninstalled the accessport. still installed is the turboxs headerback. no change. also, cleaned MAF with carb cleaner.
i noticed this happening when i got my car back from the body shop (mr. spoiler) but they deal with rotaries a lot. could it be fouled plugs?
it has hunted at first start up for about 6 months now. but now its any time at idle. especially when its just coming off significant load.
it goes from 800 to 500 to 800 to 500 to 800 to 400 to 800 to 300 then stays at 1300 for a bit, then drops down to 1000, to 500, to 800 and repeats. or something like that.
PCM threw a lean code.
im hoping the plugs are fouled and when there isnt enough load on the engine they arent sparking enough to keep it going. but still, thats $80 and i just changed them a last year. or do i have to go to a dealership?
Old Feb 7, 2009 | 03:30 PM
StealthTL's Avatar
Metatron
Do you have any screens before/after the MAF? or did you 'lose' them both?
Lack of screens can cause terrible idle hunts.....
S
Old Feb 7, 2009 | 04:02 PM
kersh4w's Avatar
Hit & Run Magnet
i have 1 screen before the MAF in the stock intake.
it did not change the idle huntin.
Old Feb 7, 2009 | 10:30 PM
hakuna matata!
compression?
Old Feb 7, 2009 | 10:32 PM
05rex8's Avatar
sold the 8... :(
bad coils or low compression perhaps.
Old Feb 8, 2009 | 02:07 PM
teknics's Avatar
Certified Mazda Tech
what was the lean code p2187, p2177, p0171? any maf codes? i'm guessing since you swap out an intake back to stock you may have forgotten the small vac hose that runs from udner the manifold to the stock box, but thats just a random dart at the board at this point.
also is it drivable or no power? or is the idle hunt the only issue?
kevin.
Old Feb 8, 2009 | 02:54 PM
kersh4w's Avatar
Hit & Run Magnet
i forgot what the code number was. :/ if its still up, i'll check, but i dont know since i reflashed it back to stock.
i have that vac hose thing capped on the manifold.
Old Feb 8, 2009 | 05:33 PM
RX8-Frontier's Avatar
hunting idle? sounds like the neutral safety switch. It'll cause the idle to cycle pretty badly when in neutral, but will settle down as soon as you put it in gear. Annoying as all get-out.
Old Feb 10, 2009 | 12:08 PM
kersh4w's Avatar
Hit & Run Magnet
interesting.
when i come to stop and it starts hunting, usually two small revs to 1500 rpm will cause it settle at 1k and then it will stay there just fine. does that sound like the neutral safety switch?
Old Feb 10, 2009 | 01:08 PM
Check your switches from the clutch bracket install...if they are not working properly you will get a hunting idle....
Old Feb 10, 2009 | 08:34 PM
kersh4w's Avatar
Hit & Run Magnet
it was doing this long before the install. also, it will hunt for idle if i have the car in gear with the clutch all the way in.
Skyl3r
Dec 2, 2019 04:51 PM
Junirol
Sep 22, 2015 06:02 AM
TheAlbinoRhino
Aug 4, 2015 09:48 PM
vetteor8
Jul 25, 2015 11:43 AM
Belalnabi
Jul 17, 2015 07:48 PM
