Opinion for lights!
Old Feb 6, 2009 | 08:08 PM
sumdeus's Avatar
According to US DOT rules, side markers have to be amber (or red in the rear) and reverse has to be white/clear.
Old Feb 6, 2009 | 08:19 PM
Hey dhan:
Here is what I recommend: get some LED bulbs form vleds.com for the parking lights and for the fogs get some from www.hoen-usa.com . They have white or yellow, both will look good.
Blue reverse lights are illegal in CA
Here's what my lights look like:
Old Feb 6, 2009 | 09:02 PM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
I have all white LED for running and side marker lights, and 2500K bulb for fog light.
I know they are all illegal in CA but I never got into any problem with it.
Even I got pulled over because no front plate 4 times (no ticket, eventually my front plate relocation kit arrived from Japan, so I put it back on).
Cop never mention about the light.
check my albums for others angle.
https://www.rx8club.com/members/krijpipudht-44394-albums-introducing-my-8-world-wide-web-33/
Old Feb 6, 2009 | 09:19 PM
sumdeus's Avatar
Finally dug it up;
"24606. (a) Every motor vehicle, other than a motorcycle, of a type subject to registration and manufactured on and after January 1, 1969, shall be equipped with one or more backup lamps either separately or in combination with another lamp. Any vehicle may be equipped with backup lamps.
(b) Backup lamps shall be so directed as to project a white light illuminating the highway to the rear of the vehicle for a distance not to exceed 75 feet. A backup lamp may project incidental red, amber, or white light through reflectors or lenses that are adjacent or close to, or a part of, the lamp assembly.
(c) Backup lamps shall not be lighted except when the vehicle is about to be or is backing or except in conjunction with a lighting system which activates the lights for a temporary period after the ignition system is turned off.
(d) Any motor vehicle may be equipped with a lamp emitting white light on each side near or on the rear of the vehicle which is designed to provide supplemental illumination in an area to the side and rear not lighted by the backup lamps. These lamps shall be lighted only with the backup lamps.
Amended Ch. 813, Stats. 1981. Effective January 1, 1982."
Old Feb 7, 2009 | 04:18 AM
Nopstnz8's Avatar
Check my sig pic. I have v-leds high power white LED parking lights, and 18 LED SMT white sidemarker bulbs with the sidemarker reflector knocked out. They look really good and you definately won't have problems with cops. They also match the stock HID's very well.
Last edited by Nopstnz8; Feb 7, 2009 at 04:23 AM. Reason: Here is a pic. Not that great though.
Old Feb 7, 2009 | 04:22 AM
+1
Yeh!
I pulled the sidemarker reflector out also.
It was so dim before the mod.
Old Feb 7, 2009 | 04:25 AM
Nopstnz8's Avatar
Originally Posted by krijpipudht
+1
Yeh!
Yeah I was surprised how much brighter and cleaner of a look it was with the reflector knocked out. I actually had no choice but to push it in so the 18 LED bulbs would fit. The reflector is still in there, but you can't really see it since it is at the end and doesn't compromise light output.
Old Feb 7, 2009 | 04:26 AM
Originally Posted by dhan
is it because the fog lights are too bright? those is300 fog lights are amazingly bright haha.
Cops just pulled me over for fun so they can check out my car.
They said my car is nice so they just give me a warning for front plate. No ticket.
I was kidding.
Old Feb 7, 2009 | 05:55 PM
smokedRX8's Avatar
9k Redline
I would say definitely go with the white VLEDs and the Hoen match fogs. I have the same exact setup as Jedi...
And here is a link to the DIY for how to remove the reflectors.
https://www.rx8club.com/showthread.p...hlight=corners
Hope this helps. And post pics when you're done!
Old Feb 7, 2009 | 06:32 PM
Hrmm how do u take out the reflectors? the thing is i have amber sidemarkers. Got to get clear ones =[
I don't think amber one has the reflectors.
For clear one, I used flat screw driver to lift and bend the base. Then I used long nose plier to fold the reflectors and pulled it out.
Everything is done thought the bulb socket. No bake-open is needed.
Old Feb 7, 2009 | 07:37 PM
Aipex8's Avatar
X e p i A
I'm not currently using these, but I keep them around as my backup bulbs. PIAA Plasma Ion Yellow H11 bulbs. They are the yellowest bulbs that I've personally seen. No yellow film needed... all bulb.
Old Feb 7, 2009 | 08:44 PM
madhatter1213's Avatar
Blue lights
I got pulled over in my dads truck for having two blue 194 bulbs in CA the best part was i was heading home after being the DD for six people.
Old Feb 7, 2009 | 09:57 PM
Aipex8's Avatar
X e p i A
Oh man ill make sure i dont go with the blues haha. Im planning on getting some fogs for around $50 the PIAA. And try to do the reverse lights to white and the turning signals to white(not the sidemarkers since i do not have clear corners.) the back ones. Tat is pretty much what you can do correct? You cant have your whole back lights white now?
First, the corner lights are not signal lights, just markers. They are on all the time, they don't flash with the signals. The front turn signals you can change to white, the rears you can not, they have to be amber or red.
Here's some CA regs for signals for ya:
Any turn signal system used to give a signal of intention to turn right or left shall project a flashing white or amber light visible to the front and a flashing red or amber light visible to the rear.
http://www.dmv.ca.gov/pubs/vctop/d12/vc24953.htm
Oh, and your reverse lights are already white, unless you are talking about going LED white.
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
CARBONRX-8
Oct 5, 2015 03:46 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
