Clutch master cylinder leaking
Old Feb 6, 2009 | 06:02 PM
cjkim's Avatar
^noob
So while installing my clutch bracket yesterday, I must have damaged the clutch master somehow... sad
So now, brake fluid is slowwwly leaking from the master (where the push rod goes through)...
Any suggestions on what to do? Would I have to replace the master or is there a way to fix this without replacing?
Also, if I end up needing to replace, any estimates on the cost + labor?
Thanks... Sad
Old Feb 6, 2009 | 06:06 PM
Its the same fluid as your brakes.
Hurry get it repaired.
Old Feb 6, 2009 | 06:08 PM
cjkim's Avatar
^noob
Yeah, I know it's the same fluid, and I won't be driving it till I get this fixed.. just wondering how I should go about this
Old Feb 6, 2009 | 06:13 PM
PM Charles R Hill
Old Feb 7, 2009 | 05:50 PM
mazdaverx7's Avatar
RX-Heaven
i would order an oem slave cylinder rebuild kit and replace the piston. most likely all you damaged was the seal on the piston and since the seal is integrated into the piston, you must replace the piston. for best results, you should hone the slave cylinder when replacing the piston.
Old Feb 7, 2009 | 06:00 PM
cjkim's Avatar
^noob
thanks for the advice, but i already bought a replacement for pretty cheap from a member.
but is there a reason you mention the slave cylinder when i'm just replacing the master? or was that a typo?.. or am i just confused
Old Feb 8, 2009 | 05:29 AM
mazdaverx7's Avatar
RX-Heaven
no, it was my typo. i meant master cylinder, not slave cylinder. my fault. i mentioned the rebuild kit because its usually a lot cheaper. at any rate, buying a new master cylinder was a good choice. it'll save time and in the long run, the peace of mind knowing the part is new is a comforting feeling.
Old Feb 8, 2009 | 08:05 PM
cjkim's Avatar
^noob
ok guys... i'd appreciate a little input as I've never done this before.
it looks pretty straightforward, but just incase I miss a step...
1. open reservoir, seal with latex glove, close reservoir
2. replace old bleeder screw with speedbleeder (thought I might as well replace it now) located behind oil filter
3. open reservoir, drain remaining fluid (shouldn't be much)
4. unscrew the three bolts holding the clutch bracket from under dash, undo the two lines from old master, remove old master
6. insert new master and reattach lines, bolt up onto clutch bracket
7. flush fluid through until no air pockets are found
8. close speedbleeder and reservoir, fill reservoir to max
9. have a beer
am i missing anything or anything to add?
Old Feb 8, 2009 | 08:29 PM
laythor's Avatar
I zoom therefore I am.
you forgot step .5
start with a beer
Old Feb 8, 2009 | 08:44 PM
cjkim's Avatar
^noob
Originally Posted by laythor
you forgot step .5
start with a beer
noted
anyone else?
Old Feb 9, 2009 | 02:29 PM
cjkim's Avatar
^noob
bump bump
any inputs?
Old Feb 10, 2009 | 08:58 AM
mazdaverx7's Avatar
RX-Heaven
sounds like you got the procedeure down to replace it. though i dont fully understand this step: 1. open reservoir, seal with latex glove, close reservoir
Old Jan 13, 2011 | 03:23 PM
maskedferret's Avatar
Oooh, shiny!
cjkim, how did the fix install on this go? No more leak?
I heard some strange popping noises on my way to work today and checked it out to see the leak below (at least the bracket seems solid still). I have no idea how long it's been like this let alone how severe. I haven't noticed an obvious drop in fluid level, so I'm hoping it won't continue after I wipe it clean before going home tonight.
SuperBlue fluid - easy to spot:
Old Jan 13, 2011 | 09:44 PM
DocBeech's Avatar
I drive at Red Line.
sealing the brake cylinder reservoir with a glove prevents the brake fluid from flowing while he does the work.
Also you can bleed to the hydrolic clutch cable. This will keep you from having to bleed the entire system.
Old Dec 1, 2022 | 10:42 PM
Qonjin's Avatar
Is there an thread on Power Brake Boosters? Mine is leaking and I think I need to replace mine. Thanks
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Stubbs
Sep 27, 2015 04:06 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
Kim Jong Illest
Sep 4, 2015 04:27 PM
