Just changed plugs, wires, and coils!! HELP!
Old Feb 6, 2009 | 05:12 PM
MWarn84's Avatar
Question Just changed plugs, wires, and coils!! HELP!
I just changed out all 4 coils, spark plugs, and wires! After i did this the car started up fine, when i went to drive it I felt as if i had lost a little power in the low rpm's. How can i check to make sure everything is working properly? I have an accessport, and i know you can check the ignition for the leading and trailing plugs, what should those numbers be while looking at the live data?!?! s
Old Feb 6, 2009 | 05:14 PM
Jon316G's Avatar
Grasshopper
Remember... it'll take a couple drive cycles to learn the trims.
Other that that, verify the plug wires are going to the correct plugs.
Old Feb 6, 2009 | 05:41 PM
MWarn84's Avatar
Thanks!! Yeah everything is connected up right, I made sure of it!! Hopefully everything will be fine in the next few days or i will be upset haha!
uZu
Dec 30, 2015 12:35 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
ne0tas
Jul 26, 2015 04:27 PM
Thechosen1
Jul 24, 2015 03:35 PM
