ACT 6 Pad/HD Pressure plate?
Old Jan 29, 2009 | 04:51 PM
nc.wiles's Avatar
I need some answers, quick. Possibly buying a ACT 6 Pad/HD Pressure plate. I have a stock 8, which is my daily drive. Would this setup be to harsh for a stock daily driver? I plan on doing more to it pretty soon, but the time being, I dont want it to harsh now or ever.
Thanks.
Old Jan 29, 2009 | 06:42 PM
Charles R. Hill's Avatar
Owner of BHR
Allow me;
The ACT line of pressure plates do tend to have a narrower friction zone than the factory/Exedy line of pressure plates. Thus, they are felt to engage a little harsher than some other clutches. Some people like this and some people do not. However, the 6-puck disc is going to add it's own level of harsh engagement to this combo.
Might I suggest the ZM8-HDMM or HDSS clutches from ACT?
Old Feb 5, 2009 | 03:01 PM
carterr68's Avatar
I have an ACT extreme and intend to get a new 6 puck sprung disk! I really like the feel and engagement of this set up. but, there's that but! I have a J-SPEC MAZDASPEED 2004 RX8 GT 6. I have also modified it too the tone of 406 RWHP and a F1 GT6 tranny. You need to go with the street performace disk. Also get the braided HYD. clutch line and always install new pilot and release bearings when you do this. I would suggest you also consider the act prolite steet flywheel w/ counter balance. when you get around to changing the front pulley set up ( I used unorthadox racing ) you will really notice how much faster it will rev and accelerate.
good luck and hope this helps!
Old Feb 6, 2009 | 04:35 PM
nc.wiles's Avatar
Thanks. That does help a lot. What have you done to get your 8 to 400+ at the wheels? Turbo?
Old Feb 6, 2009 | 05:12 PM
romycha1's Avatar
Thanks.
Wouldn't a 6-puck be a little overkill?
Old Feb 6, 2009 | 06:12 PM
Yes, read Charles advice.
Old Feb 6, 2009 | 06:28 PM
Owner of BHR
The ACT Street pressure plate will easily hold over 400 h.p. while the Xtreme Duty will hold over 600.
The Xtreme pressure plate will also destroy the welds that hold your clutch pedal together. Killed mine in less than 12,000 miles and that was NOT an anomaly.
cliffkemp
Dec 24, 2024 10:48 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Digitz0070
Oct 7, 2015 12:43 PM
