View Full Version : How do you remove the back of the nav housing?
Kippc
01-27-2009, 04:05 PM
How do you remove the back of the nav housing? Do I have to remove the whole nav unit to remove the back of the navigation housing?
alz0rz
01-27-2009, 05:07 PM
If you mean the back of the hood - yes you have take apart the "hood" assembly that rotates on the motor and remove it from the gears. There is 1 small screw on each side, once you get those off then you just gently pry it off... there are just small clips holding it on.
Kippc
01-27-2009, 07:00 PM
Thanks.
