Oil Light Wiring Question
Old Jan 27, 2009 | 10:19 AM
Nemesis8's Avatar
Bigus Rotus
Is there a way to get to the low oil light wiring? I don't have the electrical workbook, only the service book. I was curious about wiring in parallel my external oil reservoir level switch in my separate tank.
Old Jan 27, 2009 | 03:27 PM
If the level is low...the switch sends +12V to the PCM terminal 2R....so if you set the level on the tank to trigger B+ when low it would work......PCM wouldn't care where the voltage was coming from
Old Jan 27, 2009 | 03:48 PM
04RX8man's Avatar
Rotary Powered Countryboy
yes pcm just want to eigher see voltage or not see voltage!
Old Jan 27, 2009 | 04:36 PM
Nemesis8's Avatar
Bigus Rotus
OK, that sounds good. Should have all the parts together in a week. I have my Sohn on my desk, and the oil tank with level switch should be here shortly. If I can't figure it out, then I'll cool down a barleypop for you Dan.
mr. GrandGame
Sep 9, 2025 10:41 PM
Skyl3r
Dec 2, 2019 04:51 PM
MolecularConcept
Aug 5, 2015 04:43 PM
Stubbs
Jul 28, 2015 09:23 PM
