NITROUS 4PORT At
Old Jan 26, 2009 | 10:12 AM
leerx8bk's Avatar
Cool NITROUS 4PORT At
Can An 4 Port Tranny Handle A Nitrous Shot. And If Icould How Much Could It Handle With Out Upgrading The Transmission. Need The Help Thinks Any Input Is Apprenciated.
Old Jan 26, 2009 | 10:25 AM
Nopstnz8's Avatar
Yes. Search for Easy_E1. He did this with no problems whatsoever.
Old Jan 26, 2009 | 12:02 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
You can do a Super Charger , Nitrous Shot or a Turbo with the transmission. It's stronger than you think.
Old Jan 26, 2009 | 12:10 PM
hakuna matata!
Yes. Search.
Old Jan 26, 2009 | 12:11 PM
hakuna matata!
good thing the forum edited the guys posted and didn't let him post in ALL CAPS.
Old Jan 26, 2009 | 12:36 PM
leerx8bk's Avatar
Is a 100 shot to much. and with the nitrous upgrade i would have to retune my ecu as well?
Old Jan 26, 2009 | 12:37 PM
dozer's Avatar
on his 3rd rx8
100 shot WTF! no way
Old Jan 26, 2009 | 12:39 PM
leerx8bk's Avatar
so 65 is looking like what i should get. how long did does it take to install and did anybody come across any complications with it.
Old Jan 26, 2009 | 07:42 PM
MazdaRX8er's Avatar
55 is more likely.
Old Jan 26, 2009 | 07:47 PM
hakuna matata!
anything over 55 you would need to somehow retard timing.. nothing rx8 specific yet.
Old Jan 27, 2009 | 08:09 AM
NightmareX's Avatar
SPEED
Mazda is secretly working for the government an developing the Renesis100 shot rotary bomb.
Old Jan 27, 2009 | 11:14 AM
Atilla's Avatar
I am THAT guy
Search Forum Member: Easy_E1
he just recently did a dyno - look for his numbers
Old Jan 27, 2009 | 11:55 AM
Phil's 8's Avatar
Is that before or after the new manifold
Old Jan 27, 2009 | 01:20 PM
leerx: welcome.
Do a few searches and read up on a thread made by Charles R Hill regarding the use of nitrous in the RX8. That will teach you A LOT of what you need.
THEN go read up on Easy's setup. Easy_E1 has a 75 shot in his car but he does not recommend anyone else run that setup without LOTS of research and planning.
Old Jan 27, 2009 | 01:23 PM
Atilla's Avatar
I am THAT guy
looked fine to me, so i'm gonna say AFTER the new manifold
Old Jan 27, 2009 | 01:26 PM
VS8's Avatar
VS8
4 Cylinder Rotary
100 shot should be fine
Old Jan 27, 2009 | 03:14 PM
leerx8bk's Avatar
were did he get a new manifold from. did he blow the frist one, or buy a better one.
Old Jan 27, 2009 | 03:18 PM
hakuna matata!
it was the same plastic manifold, he blew it because he was spraying nitrous at low RPM and high load.
puddling resulted in a nitrous backfire. had my own a few weeks back, though not too sure why it happened.
Old Jan 27, 2009 | 03:41 PM
Don't listen to him.
100 shot is not ok.
Old Jan 27, 2009 | 03:58 PM
Renesis07's Avatar
Vtak just kicked in yo!!
leer, you are obviously a bit uneducated on nitrous with the rx8.
If you are serious, search through the major horsepower upgrades forum and search through the nitrous threads. You can also PM charles Hill if you are serious, he is pretty much rx8club.com nitrous guy.
55 shot is what we use, it has been proven to have the least amount of problems and is relatively 'safe'.
Some have used 65 shot but they have had some issues with it.
100 shot is not an option, our car is not a camaro
Just search around and you will find a lot of information thatll help you with your decision making and install.
Old Jan 27, 2009 | 04:00 PM
Renesis07's Avatar
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/rules-nitrous-use-109820/
Start by reading this thread.
Old Jan 27, 2009 | 04:05 PM
Phil's 8's Avatar
Easy blew the manifold off his 8 at seven stock but don't tell him I told you Luckily some one had a 4 port manifold and he was able to drive it home I think that was his 100 shot This is only for fun and to tease Easy - read what CRH has to say about nitrous before you blow both the manifold and yourself up.
Old Jan 27, 2009 | 04:08 PM
Atilla's Avatar
I am THAT guy
^ that's rightt! i remember i heard about that...
Old Jan 27, 2009 | 06:56 PM
Easy_E1's Avatar
What's all this talk about me?
Yes I blew up a manifold. High engine Load and Low RPM's are not a winning combination. While spraying Nitrous.
I would suggest you go with the 55 Shot and NOT A DRY shot either. It must be a WET SHOT.
The Nitrous by itself with out added fuel is a NO WIN situation. It will run lean until it blows up. Which would not be very long.
I'm running a 75 shot at the moment. But I have many hours of tuning time with Mazdamaniac. Many hours! And I still feel a little leery every time I floor it.
Just do the 55 shot with the ZEX 82021 kit from BHR. And get the BHR throttle Body Spacer. Makes for a much cleaner and simpler install.
And yes I have a 4 port AT putting down 174 WHP.
ErwinN
Sep 23, 2015 09:29 PM
Turbonostic
Rotary Swaps
10
Sep 19, 2015 11:53 AM
Formula 420
RX-8 Racing
Mar 20, 2004 04:54 PM
