H.I.D. fogs not working!
Old Jan 24, 2009 | 11:22 PM
Rx8driver08's Avatar
Angry H.I.D. fogs not working!
I just put in my H.I.D. fogs and when i went to turn them on nothing happened. I went back and connected everything again and still nothing. I used gloves when putting the bulbs in so i didnt touch them. Anyone have problems with their fogs too? And also couldn't get out the rear 194 bulb to replace with an L.E.D. from superbrightleds.com. I tried wiggling it out without breaking or bending the contacts, maybe its just too cold to take out and my hands are being retarded its like 28 degrees out lol. Any tips on how to get it out?
Old Jan 25, 2009 | 05:52 PM
czar's Avatar
Almost boosted
try connecting the hids straight to the battery to test them.
Old Jan 25, 2009 | 07:34 PM
Lord ET's Avatar
Is that a bike rack?
are they real HIDs or are they just blue tinted "HIDs"?
Old Jan 26, 2009 | 09:34 PM
They are real HIDs, but i'm gonna check them with my battery as soon as it warms up out a little out, but i heard that if they don't light up i need a wiring harness in order for it to work. But some people say theirs are just as simple as plug and play.
Old Jan 26, 2009 | 09:59 PM
czar's Avatar
Almost boosted
if they dont light up after connecting it to a battery. pretty good sign they dead unless the car doesnt start then your battery is dead ^_^,
possible to blow a fuse i guess, never did in my 6 though i had 55watt hids in the low beans and 35watt hids on the fogs
Old Jan 28, 2009 | 01:32 PM
Tested them with my battery and they lit up, i also checked the fuse for the fogs and the connection is fine. Maybe I'm just not getting enough power from my stock wiring harness to the ballasts. So is my last option to buy an H11 wire harness? I read that when you use a wire harness to attach HIDs that it still uses the stock fog switch to turn them on an off?
Old Jan 28, 2009 | 01:45 PM
onyx8's Avatar
Look for an H11 relay harness. This way the ballasts are connected directly to the battery, and the stock harness is only used as a switch. This will be direct plug n play as well, only you wont risk frying your stock fog wires in the long run. Yes you will be able to use the turn stalk to operate them.
Old Jan 28, 2009 | 01:56 PM
Thanks onyx8 i appreciate it
Old Jan 28, 2009 | 02:13 PM
Socket7's Avatar
ಠ_ಠ
I second Onyx's solution. Never run power for HID's through a stock wiring harness not designed for HID's. If you're lucky, you'll only blow a fuse. If you're unlucky, you set your wiring harness on fire. use the stock wiring to trip a relay to turn them on.
Old Feb 2, 2009 | 04:27 PM
philipchan's Avatar
i did my fog light to HID too (3000K), i got no problem, but the HID kit is actually has positive and negative connect , is easy to put the wrong side, just like the LED bulbs, just switch the connection of the Ballet then it should be fine, i installed mine
9krpmrx8
Nov 5, 2015 11:45 PM
wayloco
Sep 1, 2015 09:03 PM
RotisserieEngine
General Automotive
11
Aug 6, 2015 06:34 PM
SayDfuse
Aug 3, 2015 10:41 PM
Stubbs
Jul 28, 2015 09:23 PM
