To much coolant. Now what do I do?
Old Jan 24, 2009 | 06:50 PM
DOMINION's Avatar
I don't buy Kool-Aid
Exclamation To much coolant. Now what do I do?
So my coolant was low. I added 16.9oz of watter and now its over flowing from the over flow line on the right of the coolant tank
What should I do?
Old Jan 24, 2009 | 06:52 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Got a turkey baster?
Keep it off the power steering connectors or you'll have trouble there.
Old Jan 24, 2009 | 09:40 PM
AAChaoshand's Avatar
Rotary Powered
Were you not paying attention as you were filling it? I mean come on...
Old Jan 24, 2009 | 09:41 PM
staticlag's Avatar
The Professor
Agreed!
Old Jan 24, 2009 | 09:43 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Not helpful...
If you have any hose laying around, maybe you could connect it to the overflow hose port and drain the excess into a container...
Otherwise, its turkey time!
Old Jan 24, 2009 | 09:44 PM
Rotary Powered
May not have been helpful but my point is still made, don't do something to your car if you don't know what your doing.
Old Jan 24, 2009 | 09:58 PM
Vyndictive's Avatar
Then how will you learn how to do it?
Could wait for someone to teach you, or just pay someone... or just try it and see what happens and be ready to fix your mistakes.
I've only learned by reading these forums, another club member helping me, or doing it myself and sometimes messing it up and then having to figure out how to fix it.
Old Jan 24, 2009 | 10:04 PM
Swift8's Avatar
I'm new to this forum but as I read through, I see more and more of these kinds of comments. The whole point of a forum is to share your experiences and knowledge so that everyone can learn.
No one learns anything from comments like that, and your not the only one who makes them. Yes, he screwed up...but he admits he screwed and has now come to the forum for HELP, not to be bashed.
Anyways, one of the easiest things you can do has been suggested with that turkey baster.
My $.02
Old Jan 24, 2009 | 11:27 PM
ken-x8's Avatar
Slip-ups happen. And you never know what you know or don't know until you give it a try. "Whoops" is the world's best teacher.
Dominion - two things to consider. First, if you use a turkey baster, that baster's future use will always be for coolant. Never food. Second, if you use a normal antifreeze mix, adding just water dilutes it. If you ever contemplate going to a colder climate, you'll need to drain the system a bit and re-balance it. Consider getting an antifreeze tester, which looks like a turkey baster with a float in it. You can use it to suck out the excess and also see how the mix is.
Ken
Old Jan 24, 2009 | 11:30 PM
HockeyRX-8's Avatar
TNC
I hope your car doesn't have the FL-22 coolant
Old Jan 24, 2009 | 11:37 PM
Ken
Thats exactly what I did. I use it to suck out extra coolant AND to test the coolant's capability.
Old Jan 25, 2009 | 12:31 AM
Nubo's Avatar
Lubricious
I ended up overfilling mine when I changed the coolant. As the engine warms it sucks in coolant and you keep adding to the resevoir, revving occasionally to bleed any air bubbles out. So yeah, it's pretty easy to overfill if you've got a big funnel filled on top of the resevoir waiting for any further burps. No biggie. I already routed and extended the drain hose when I fixed my powersteering connectors, so I just let nature take its course -- it can overflow however much it likes.
Old Jan 25, 2009 | 03:38 AM
DOMINION's Avatar
Thanks for the turkey tip!
Old Jan 25, 2009 | 06:38 AM
mysql's Avatar
Doppelgänger
If you overflow your coolant, you can jack up one side of your car a little bit. If you need to tip it even more, place one jack on top of another jack and jack up both jacks to get some serious tippage. OR you can try cutting the power line to your radiator fans and allow the car to overheat for about 30 minutes. This should cause the coolant to boil and it will overflow out the top.
My personal fav method involves displacing coolant by dropping rocks into the overflow tank.
Old Jan 25, 2009 | 06:42 AM
mysql's Avatar
Doppelgänger
of course i am joking. I decided I needed this disclaimer because someone would try it, destroy their car then try to sue me.
Old Jan 25, 2009 | 08:29 AM
AJ's Shinka's Avatar
Enthusiast
Man if you can't be helpful just don't say anything. I've seen worse mistakes at the stealerships or jiffylube overfilling my oil. Don't him what he should or shouldn't do. If you do it yourself you can always correct any mistakes you make. Like you have never made a mistake.
I hope I never see you post having any problems with your car, because you'll get lit up. I would go into it more, but I'm not trying to get banned over a sorry unsympathetic piece like you. Thank you for making these forums a better place, I mean come on...
end rant.
OP: Glad to see your problem was rectified.
Old Jan 25, 2009 | 09:24 AM
Man, I just did that, when my car moves it made some funny sound then my engine blew up !
Im so gonna sue you !
Old Jan 25, 2009 | 09:27 AM
ken-x8's Avatar
You of all people overfilled?
Paging AAChaoshand...
Ken
Old Jan 25, 2009 | 09:33 AM
rofl.
Old Jan 25, 2009 | 12:18 PM
DOMINION's Avatar
lol mysql killed my car! thanks AJ
Old Jan 25, 2009 | 12:55 PM
While your at it... put a longer hose on the overfill resoviour.
Route to the bottom of the car or else you will get a bug mess and antifreeze will eat up the engine bay when it sprays out.
Old Jan 25, 2009 | 01:00 PM
DOMINION's Avatar
Yea man I'm going to homedepo on my way home from work to get one
Old Jan 25, 2009 | 01:08 PM
Brettus's Avatar
Boosted Kiwi
This is a special device developed for just such an occasion .
Instructions are simple :
Remove overflow tank cap
drive through loop de loop at steady 30mph
check water level and repeat if neccessary
Old Jan 25, 2009 | 01:09 PM
zoom44's Avatar
did you run it after filling?
Old Jan 25, 2009 | 01:25 PM
04RX8man's Avatar
Rotary Powered Countryboy
damn i put rocks in my tank and now it's overheating...oh well just drive faster and it will cool down!!!hha!!!!
