How do you beat the CEL?
Old Jan 22, 2009 | 10:18 PM
lamarvannoy's Avatar
I have a catless midpipe on my car and the CEL came on. How do you beat it? i want it gone
Old Jan 22, 2009 | 10:21 PM
chancejat's Avatar
Drive it like u stole it!
access port from mazdamaniac....google him
Old Jan 22, 2009 | 10:25 PM
Easy_E1's Avatar
Click the link in my "SIG". The one that says MAZDAMANIAC.com
any other way? no fouler or nothing?
Old Jan 22, 2009 | 10:33 PM
paulmasoner's Avatar
Asshole for hire
flash tuning is the only way
Old Jan 22, 2009 | 10:34 PM
chancejat's Avatar
fouler no worky bc car is very smarty.....
Old Jan 22, 2009 | 10:36 PM
StealthTL's Avatar
Metatron
No, foulers won't do it, it's not a Subaru.
S
Old Jan 22, 2009 | 10:37 PM
MazdaManiac's Avatar
AZ
lulz
The "anti-foul" plug extensions sometimes work on the 2004 models, but rarely.
Either get a reflashing system or put a piece of electrical tape over the light.
Old Jan 23, 2009 | 11:06 AM
04RX8man's Avatar
Rotary Powered Countryboy
^there is your man for the AP!
Old Jan 23, 2009 | 11:36 AM
RX8-Frontier's Avatar
Haven't done this, yet, but you've got two other options; only 1 will work...
1) put a resister on the line on the 2nd O2 sensor. If the PCM is checking for resistance difference, then this will work. OBDII vehicles don't typically use this method, though. Most likely won't work.
2) put a rectifier diode on the line on the 2nd O2 sensor. If the PCM is checking for voltage drop (newer cars typically do), then this will work.
I guess, in theory, it could be a combination of the two as well, but those are the only 2 ways I know of that will cost 'ya less than $2 and a little bit of your time. Gonna' be up to you to find the right size of each to use. I don't have any acceptable range values of the O2 sensors our car uses off-hand.
Old Jan 23, 2009 | 11:38 AM
ken-x8's Avatar
Have you considered upgrading your midpipe to one that has a cat?
Ken
Old Jan 23, 2009 | 12:25 PM
Ken
Yeah... Like he said...
I'll even do 'ya one better and offer 'ya my stock "upgraded" part for your POS catless midpipe... I mean, I hope you didn't pay full price for that thing since it didn't come with a cat! Should've been some sort of discount or something... I would trade 'ya striaght-up and all, but mine's got the cat, so it's worth more, right...?
Old Jan 23, 2009 | 12:47 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
. . . I just laid down and took my CEL from going catless... you knew it would throw a CEL before you installed it... Just deal.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
