Int-X Light Question
Old Jan 20, 2009 | 05:05 PM
baysj's Avatar
So the battery died on the car. After attaching the jumper cabled I noticed with the key in the "On" posisiton the int-x had only the green light on, not the yellow. I know the yellow light is susposd to be on. Before i start pulling fuses does anyonr know the issue? Im going to guess its going to be a fuse.
Old Jan 20, 2009 | 05:15 PM
staticlag's Avatar
The Professor
throttle position sensor is miscalibrated.
Need to go into the software and adjust the throttle till it zeroes out.
Old Jan 20, 2009 | 08:58 PM
baysj's Avatar
Hmm, wonder how that happened with the car simply sitting? Any clue?
Old Jan 20, 2009 | 09:19 PM
staticlag's Avatar
The Professor
Maybe it got reset when you jumped it.
I would check your maps before you go into boost.
Old Jan 20, 2009 | 09:20 PM
staticlag's Avatar
The Professor
Is this a new install? Cause usually the throttle pos. sensor can vary from car to car and needs to be calibrated before operating on a specific vehicle.
Old Jan 21, 2009 | 07:42 AM
baysj's Avatar
Its a somewhat new install. The reason the battery died is the car has been sitting for a month. I did the install and drove it to where im storing it until I get it tuned. I get it tuned next week so It would be nice to get it running again before hand. The previous times I tried to start it the yellow light was on. Thats why I'm confused about it changing.
Old Jan 21, 2009 | 09:04 AM
staticlag's Avatar
The Professor
The throttle could be sticking or something, try checking it for obstructions.
Old Jan 25, 2009 | 10:22 PM
baysj's Avatar
I have been out of town and unable to get to the car until today. I checked the throttle body and noticed with the car in the on position it was making a humming sound. The light on the int-x was still not on. I decided to start the car which it did right away. I let it idle for about 5 min then killed it without moving it. I moved the key to the "on" posistion. The yellow light on the int-x was back on. I disconnected the battery then re-connected it. The light went out. The car started without a problem again. I decided to buy a serial to USB cord to try to see the throttle position but i was unable to see the information on the int x. I noticed I only got the serial cable when I bought the int-x and not the other peice. Is this required for the laptop to interface with the int x? Im guessing yes. I have a appointment to get the car tuned on tuesday do you think PFS will have the required hardware? If not anyone in Maryland have one I can borrow?
Old Jan 25, 2009 | 11:25 PM
Need the dongle......
Skyl3r
Dec 2, 2019 04:51 PM
Kahl
Aug 20, 2015 11:49 PM
tgaffner
Aug 20, 2015 10:55 AM
dancingdan42
Aug 19, 2015 09:29 AM
Stubbs
Jul 28, 2015 09:23 PM
