Please Help!!!
Old Jan 11, 2009 | 10:18 PM
NVmyRX-8's Avatar
Rotarian
Please Help!!!
WTF IS WRONG WITH MY CAR?
i think i might have flooded it but idk
i'll be driving down the road and then as i slow down when im pulling up to the stop light, the rpm's lower (like usual) but then instead of stopping at 1k, they go up and down from 1k - 250 rpm's and then the engine shuts off
any clue what could be wrong?
• spark plugs
• fuel pump
• throttle body
• or flooded engine
please help if any of the minorthings, any clue what could help??
Old Jan 11, 2009 | 10:29 PM
G3tR3DDY2GR3DDY's Avatar
i would say none of those. I would say emmissions related or possibly ssv or coils. By emmissions i mean air pump or vaccum leak.
Old Jan 11, 2009 | 10:33 PM
NVmyRX-8's Avatar
Rotarian
what are the ssv or coils?
i just installed a new intake
would tht have anything to do with the air pump or vaccum?
Old Jan 11, 2009 | 10:38 PM
I8U's Avatar
I8U
By coils, he means ignition coils and ssv is the secondary shutter valve. Did you reset the PCM?
Old Jan 11, 2009 | 10:40 PM
NVmyRX-8's Avatar
Rotarian
i am sorry but i have no clue what the PCM is or what it stands for
how do you reset that?
Old Jan 11, 2009 | 10:43 PM
I8U's Avatar
I8U
The PCM is the cars computer. There are two reset procedures, one for the NVRAM and the other for the KAM. Neither will erase your radio presets:
1) With the key in the off position, press and hold the odometer reset button and turn the key to on;
Continue to hold the odo button until the odometer reads "TEST" and then release.
2) Turn the key to off and repeat step one.
This will reset the entire PCM except the KAM which contains the sensor profiles amongst other things. You can reset it with the familiar procedure:
1) Turn the key to on
2) Depress the brake pedal rapidly 20 times in a row until the oil pressure gauge sweeps to halfway and back again.
Old Jan 11, 2009 | 10:50 PM
snipaz2420's Avatar
the bukkake master!
put your stock intake back on and see if you are still having problems
not so much that problem as i think with his new intake he forgot to cap off the vaccum line that goes to the VFAD actuator and the check valve. BUT it wouldnt hurt to do this anyway. Ive never had to but its a good thing to do and learn
Make sure all lines that were on the stock intake are either reconnected or capped off with a screw or cap.
Old Jan 11, 2009 | 11:36 PM
NVmyRX-8's Avatar
Rotarian
i reset the pcm both ways i dont know if it did anything
i am pretty sure that i plugged everything back up the only thing i took of was the censor that was on top of the tube that was connected from the intake box to the throttle body
i do know that there is a major gap from where to old intake box was set up to where the new one sits
Old Jan 11, 2009 | 11:50 PM
take pics in these circles... so that we can see your vaccum hoses and connections. The gap is normal its not supposed to be oem style, just close
Old Jan 11, 2009 | 11:51 PM
StealthTL's Avatar
Metatron
G3treddy is probably right, check the nipple just behind and below the throttle body, make sure it's not open, it must be capped off.
S
Old Jan 12, 2009 | 12:12 AM
NVmyRX-8's Avatar
Rotarian
ps, i really appreciate all of the help guys
Old Jan 12, 2009 | 12:57 AM
well the upper hoses look fine, but the lower part is what you are probably overlooking. Here is a diagram of the hose routing. There is a green plug that you probably disconnected and left. Thats fine, but make sure the hoses that go to all that stock VFAD actuator garbage is blocked off now.
Old Jan 12, 2009 | 01:07 AM
\\Konig\\'s Avatar
turrrbo!
i hope you have a screen installed in front of that MAF sensor in the intake!
Old Jan 12, 2009 | 01:17 AM
and i hope YOU ^ post more pics of your gf
i would assume the shitmota intake has a screen built into it.. havnt really heard any issues with them. Most people usually take the hose off the intake actuator and just leave it laying around without capping it off :P
Old Jan 12, 2009 | 12:43 PM
\\Konig\\'s Avatar
turrrbo!
just saying cause i know the earlier simota intakes didnt come with a screen (i bought one a long time ago and its sold now) so you should make sure it has one!
haha and pics will come....eventually =P
Old Jan 12, 2009 | 08:09 PM
NVmyRX-8's Avatar
Rotarian
I took off the intake so i could see better
Where exactly is the VFAD acutator?
Can you circle where it is?
and the hoses that you circled one and two?
i dont think i see them but i just might be over looking them
Old Jan 12, 2009 | 08:36 PM
NVmyRX-8's Avatar
Rotarian
Oh and the #2 on the picture, remove it and cap it off?
What is that for?
Old Jan 12, 2009 | 08:44 PM
follow the hose in the drawing with the #2 on it up to the intake where the throttle body is. that is likely not capped off.
the vdaf is in front of the of the radiator in the bumper. you have to remove the bumper to get to it.
that is if it still is there..
Old Jan 12, 2009 | 09:01 PM
Z0oMzo0m's Avatar
i have mazdspeed. i didnt cap antyhing off. i have one vac hose with a actuator attached just laying in my bay. has to wires connected to it. (brown and green i think) it was the vac hose that runs to front bumper. that needs to be capped off?? what if its not?
Old Jan 12, 2009 | 09:12 PM
those are the connections for the vdaf.
give me a minute. i will get a photo of what should be capped.
Old Jan 12, 2009 | 09:17 PM
here you go.
it is on the underside of the upper intake manifold where it meets the throttle body..
hope this helps.
Old Jan 12, 2009 | 09:20 PM
NVmyRX-8's Avatar
Rotarian
hmm ok gimme a second
umm, plug it with what?
Old Jan 12, 2009 | 09:24 PM
Z0oMzo0m's Avatar
a cap of some sort, you can get them at autozone.
Old Jan 12, 2009 | 09:32 PM
Z0oMzo0m's Avatar
well that is def the same hose in my bay thats open.. WHY does it need to be capped off? am i harming somthing? i havent had any problems...
