Buger
01-07-2003, 03:33 PM
Standard audio system has am/fm tuner and 4 or 6 speakers with total rater power of 100W.
Premium audio system has nine BOSE speakers:
2 x 9" Nd woofers (neodymium-boron magnets)
1 x 6x9" midrange speakers
2 x 2" front tweeters
2 x 2" rear tweeters
1 x 80mm tweeter
AUDIOPILOT
Quick_lude
01-07-2003, 03:47 PM
What is in the door panels? 9" woofer? :confused: Where does the 6x9 and 1 80mm tweeter go?
pelucidor
01-07-2003, 04:09 PM
The BOSE has 2" tweeters! Not still made of crappy (and hence very cheap) paper are they? Every other decent speaker manufacturer uses 1" metal dome tweeters I believe.
Quick_lude
01-07-2003, 04:15 PM
Ok but there are speakers low in the door correct? And the tweeter up by the window/a pillar. So what goes in each front door? :confused:
Aesculapius
01-07-2003, 04:18 PM
Buger,
Where are you getting all this info?
NOT that I am complaining.....:)
zoom44
this from rotarynews.com. we should really move this to the audio forum!
http://images.rotarynews.com/images/Detroit2003_1/mvc01315.jpg
Fëakhelek
01-07-2003, 04:21 PM
There must be 2 6x9s. Otherwise:
1 x 80mm tweeter
Doesn't add up to 9 speakers, only 8. In fact, the photo (from zoom44) just finished displaying on my machine. The 6x9s almost have to be in the doors.
Fëakhelek
01-07-2003, 04:26 PM
Hey, I just thought of something. If there are 2 tweeters up front and 2 in the back, and (I assume) 2 9" woofers on the rear deck, and one more tweeter (probably in the center of the dash or something) and 2 6x9s in the front doors then won't the sound in the back seat suck? Two subs behind you and tweeters but all the midrange up front can't be good.
Good thing I will always be in the front! :D :D :D
Fëakhelek
01-07-2003, 04:48 PM
So now I find this photo. What are those, tweeters in the sun visors??? Both visors look the same. Now that's weird.
pmacwill
01-09-2003, 10:37 PM
2 x 9" in front doors
2 x 6x9" in back
check out the press release or browse through the other threads, their are design diagrams of the speaker layouts floating around...
Hercules
01-09-2003, 11:13 PM
Originally posted by Fëakhelek
So now I find this photo. What are those, tweeters in the sun visors??? Both visors look the same. Now that's weird. No, they are just sun visors but instead of a full covering they made holes thru them so they still allow viewing thru them and also add to the 'lightweight' ideas that makes the car.
DonG35Miata
01-12-2003, 02:46 AM
From what I recall, Audiopilot is something you do NOT want to have! The people on the 350Z board said it is annoying as he11 and doesn't work. Some are demanding a way to disable it.
