StealthTL's Greddy kit install....
Old Jan 9, 2009 | 09:36 AM
StealthTL's Avatar
Metatron
Cool StealthTL's Greddy kit install....
Basic Greddy kit, bought used.
Greddy blowoff valve, installed by kit owner. (nice job)
Stock maf pipe, with stock mesh before and after the maf.
REALLY big intercooler.
Custom silicone reducer elbows to fit kit piping to intercooler.
Using stock oil pan instead of the Greddy, because it has my oil pre-heater mounted.
Presently in process of AP tuning.
S
Attached Thumbnails StealthTL's Greddy kit install....-20090109161453.jpg   StealthTL's Greddy kit install....-20090109161758.jpg   StealthTL's Greddy kit install....-20090109155420.jpg
Old Jan 9, 2009 | 09:43 AM
StealthTL's Avatar
Metatron
Mounted six Prosport gauges,
Boost, EGT and water temp on top of the dash,
and oil temp, oil pressure and fuel pressure in an RB ashtray pod.
(Using AP for air/fuel ratio readout)
S
Old Jan 9, 2009 | 09:47 AM
StealthTL's Avatar
Metatron
Cool
Mounted 2x10" rad fans behind the i.c., wired in series/parallel for two-speed operation.
Figured it can't hurt!
S
Old Jan 9, 2009 | 09:50 AM
StealthTL's Avatar
Metatron
Cool
Wrapped the downpipe, header and midpipe in fiberglass tape, secured by stainless bands and soaked in hi-temp paint. Made a nice hard coating when it finally stopped smoking......
S
Attached Thumbnails StealthTL's Greddy kit install....-20090109161911.jpg   StealthTL's Greddy kit install....-20090109161935.jpg
Old Jan 9, 2009 | 09:51 AM
blackenedwings's Avatar
Life begins @ 30 psi
Very cool, congrats on getting the turbo in the car. Make sure to post some feelings about the new power when you get it driving. How hard was the install?
Old Jan 9, 2009 | 10:02 AM
StealthTL's Avatar
Metatron
Install went well, other than I forgot to replace the motor mount when the instructions said, so had to undo quite a bit to get it back in. (Doh!)
Interested in Kane's comment that "...it's easier if you take the driver side mount off, too" Is it worth the trouble?
I had my motor sitting on wood blocks, so it didn't move anyway.....
Does anyone think the huge intercooler might reduce/minimize boost spikes?
As for the 'feel', I had thought that the power would be all in the 'boost' section of the gauge - normal feel in vacuum, with push and power coming on as the manifold saw positive psi, however my butt-dyno feels plenty'o'urge even at minus 5........didn't expect that.
S
Old Jan 9, 2009 | 10:16 AM
gregs's Avatar
Pull My Finger
very nice wrap job there....is it necessary to have screens before and after the maf sensor?
Old Jan 9, 2009 | 10:22 AM
DrewMan's Avatar
Culpam Poena Premit Comes
You really need to clean your engine bay!
Would it be possible to reinstall the airbox with a bit of choppage?
Old Jan 9, 2009 | 10:34 AM
bose's Avatar
Reginald P. Billingsly
Looks great Steath, how long did the install take, and did you have any help?
Old Jan 9, 2009 | 10:35 AM
StealthTL's Avatar
Metatron
Yes, the engine bay is disgusting, but it's minus 30* outside and I ain't gonna wash it till spring! (April.....) It's six years old now.
I'm pretty sure with some good aluminum skills, the airbox could be used - I've seen proposals for the stock box with a side outlet, too.
The stock setup has before'n'after screens - without a turbo - if the impeller causes any resonances, or flutters during a surge, the screen may be useful....
S
Old Jan 9, 2009 | 10:41 AM
Red Devil's Avatar
I don't follow putting fans on the intercooler. This makes sense on the radiator or oil coolers as both water and oil systems are constantly absorbing heat from the engine and are in need of dissipation even at a standstill.
Those conditions don't apply to your FI system and by extension the intercooler. It will only need to perform its task under load. And you don't want those fans impeding flow through the intercooler and negatively impacting its performance.
Old Jan 9, 2009 | 10:42 AM
StealthTL's Avatar
Metatron
Install took about a week, taking it real slow - five hours to warm the garage, then a couple hours of wrenching before bed. Hardest part was probably the oil supply - I fitted a 'sandwich' filter adapter with three holes - oil press, oil temp and turbo oil supply, then just had to work out how to angle it right. (No leaks! WooHoo!!)
Friggin gauges took ten days! Going thru the firewall was a bitch, so I installed a big cable of 12 wires, then just joined up on each side, worked well except the EGT, which has dedicated wires.
You're probably right about the fans - but given that the I.C. completely blocks the rad opening (!) I figured some mechanical air movement might be required......
S
Old Jan 9, 2009 | 10:43 AM
RXTC's Avatar
Pistons EH!
cool deal man! Hey does anybody know if theres any proven results with the heat tape on turbo applications with the 8?
Old Jan 9, 2009 | 10:48 AM
mysql's Avatar
Doppelgänger
Yeah, you should feel gains even at -10" as the turbo is gently pushing additional air towards the engine.
I'd get rid of the fan too. there is no need to cool intercooler when at a stand still. get a meth kit if you want lower temps
Old Jan 9, 2009 | 10:59 AM
StealthTL's Avatar
Metatron
Fiberglass tape was in response to the floorpan-roasting carpet-singeing rubber-melting heat....
S
Old Jan 9, 2009 | 11:24 AM
grats stealth! I know it's not exactly the turbo you wanted to install but glad you're boosted.
Old Jan 9, 2009 | 11:29 AM
alienRX8's Avatar
Boosted!!!
Nice stealth. Now its time to upgrade to a GT3071r
Old Jan 9, 2009 | 11:34 AM
StealthTL's Avatar
Metatron
OOH!
thats cold....
S
Old Jan 9, 2009 | 11:38 AM
alienRX8's Avatar
Boosted!!!
while you waited for what?
Old Jan 9, 2009 | 11:39 AM
alienRX8's Avatar
Boosted!!!
ohh I saw in your sig you have it ordered but it hasnt arrived yet
Old Jan 9, 2009 | 11:44 AM
zoom44's Avatar
great job stealth
your mods look good too jedi
Old Jan 9, 2009 | 11:46 AM
^^^ stay away!!!
Old Jan 9, 2009 | 12:25 PM
Brettus's Avatar
Boosted Kiwi
S
Yeh - that was a big (and pleasant) surprise for me as well . I have a boost guage installed on the turbo outlet ad I see up to 5psi there while the inlet manifold is still in vacuum .
Congrats on the install . Have you done any full on boosting yet ?
Old Jan 9, 2009 | 12:33 PM
Jasonawojo's Avatar
Nice Stealth! How much PSI are you planning on running?
Old Jan 9, 2009 | 02:11 PM
chickenwafer's Avatar
Nope
Good job Doc. I especially like how you patted yourself on the back with the BOV install (LOLz)
