LED Wiring
Old Jan 6, 2009 | 04:02 PM
Spoolin8's Avatar
LED Wiring
I know that other member sells those LED's that shine on the pedals when you either open the door or turn on the lights. I already have my own LED's and they are wired up but after searching i have failed to find were i need to wire them to so that they come on when the door opens and dims after closing just like the overhead lights which i have already switched to LED's.
Old Jan 6, 2009 | 04:48 PM
Quinchu's Avatar
Switcher
You can easily do this by tapping into the map fuse (or the room fuse) and then grounding the ground wire.
Search "Footwell LED" and you should find quite a bit of information. I tapped into the map lights on mine, and then just grounded the black wire.. Although mine was only a 2 wire setup so it was easy to do. I can't remember the wire color, but I'll look when I get off work. So in like 2 hours.
Old Jan 11, 2009 | 05:30 PM
techerpaintball's Avatar
Rotor Head
do u have ne pics of ur lights on? i want to do some LED interior lights as well but im not sure how to go about doing it. i was also wondering wut lights u got.
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
