Oil Scent In Cabin after Tranny Oil Change
Old Jan 5, 2009 | 07:21 AM
RX8Prodigy's Avatar
So I changed my Tranny Oil on my 04 MT, and all went well, seemingly. This was 4 days ago. Since then, two persons have asked me why inside my car smells so oily, like a garage. When I put my nose down to the shift stick i can smell a strong oil odor.
I checked underneath the car and there appears to be no leaks.
Other than a leak underneath the car, what could cause the scent of oil to come up through the center console?
PS: Does anyone know a good place where I can buy my 4th Gear Synchronizer mail order?
RX8Prodigy
Old Jan 5, 2009 | 07:43 AM
staticlag's Avatar
The Professor
http://www.mazdamotorsports.com/
Gear oil has a high amount of sulfur in it. It is common for the smell to permeate into the cabin for a few days after a gear oil change.
Old Jan 5, 2009 | 05:01 PM
Nubo's Avatar
Lubricious
Yeah, it only takes a small amount to produce a noticeable "bouquet". It'll pass. Most people aren't familiar with the smell because they never get their trans oil changed.
Old Jan 5, 2009 | 05:26 PM
How did they fill it up? if they opened up the shifter and dumped it in there..they could have spilled..or ripped the boot seal?
Old Jan 5, 2009 | 05:35 PM
rotary.enthusiast's Avatar
The Local Idiot
The small amount of gear oil that gets on the outside of the transmission is enough to smell inside the car. I changed mine a month ago and I can still smell it faintly. Some carb cleaner on the transmission housing might take care of it... personally I don't mind it enough to bother though.
Old Jan 6, 2009 | 07:11 AM
RX8Prodigy's Avatar
It was filled through the fill hole on the tranny housing with a tube and hand pump (A DIY Job). It seems that I only smell it when I rev the car (maybe thats in the mind...i will have to check). At idle I smell nothing, but under rev the scent permeates from the gear/center console area. The oil was changed on new years day. I spilled some (almost all - thought the catch pan was under the drain...it wasn't) in my dirt yard and it still reeks, after days of soaking rain.
PS: Also got some on my gloves and they still reek after two wash cycles :-)
So based on comments, there is a chance I may have a torn boot or may just need to take some carb cleaner to the tranny housing.
Old Jan 6, 2009 | 11:12 AM
Carb cleaner and air freshner.
Skyl3r
Dec 2, 2019 04:51 PM
Dokuji
Nov 1, 2016 02:51 PM
BigMikeATL
May 26, 2016 12:31 AM
Zank300
Aug 26, 2015 07:40 PM
GrAfiX
Aug 24, 2015 08:08 AM
