Problems removing passenger side motor mount
Old Jan 3, 2009 | 12:50 PM
turborx8's Avatar
Boost 4 Life
I am trying to remove my turbo and one of the steps is to remove the passenger side motor mount.
I was able to remove the bolts from the mount no problem. I placed a floor jack under the front right corner of the oil pan and I raised the engine to the point that I am lifting the whole front end of the car. I still don’t get enough room to remove the mount.
Anything else I can try?
Old Jan 3, 2009 | 01:07 PM
Derex'8's Avatar
ReDuX
You are referring to the bracket right?
Ensure you have all the bolts removed should be exactly 4 bolts. Does the bracket even budge? If so it's just a matter of wiggling and maneuvering it out, thats all.
Old Jan 3, 2009 | 01:31 PM
turborx8's Avatar
Boost 4 Life
I havent tried to removed the bracket.
I am using Jeff's instructions here: http://www.mazdamaniac.com/upgrade/G...20Upgrade.html
Steps 9-10-11 is what I am trying to do.
Old Jan 3, 2009 | 01:52 PM
Easy_E1's Avatar
I would think that the engine would go up far enough to pull the mount out. Strange.
Old Jan 3, 2009 | 02:42 PM
turborx8's Avatar
Boost 4 Life
Yeah, very strange. I only need about 1/2" extra to pull it out.
Does the motor mount bracket need to be removed to take the turbo out?
I don't see it mentioned anywhere in Jeff's instructions.
Old Jan 3, 2009 | 03:01 PM
staticlag's Avatar
The Professor
Yes you need to remove both the bracket and the rubber motormount.
D
Crazy.8
Apr 18, 2017 03:17 PM
SayDfuse
Aug 3, 2015 10:41 PM
Jazzmeson
Jul 31, 2015 01:48 AM
Jazzmeson
Jul 31, 2015 01:47 AM
marc2820
Jul 26, 2015 10:47 PM
