Oi leak
Old Dec 31, 2008 | 12:11 PM
Trex's Avatar
Oi leak
hey guys just looking for a little help, so i just noticed the other day that i had some oil leaking, the dealer as usual topped up the oil a bit too much as i checked the oil level, my question is if oil is topped up can this be the cause for the oil leak? the service guys at my dealer are a bunch of lemmings who have no clue on what thier doing, shud have never got the car from dufferin mazda as they are probably the worst dealership when it comes to knowledge and priceing, lol only reason i go thier is cuz they threw in free oil changes in my package....when i questioned them on the leak they said they put a seal on around the oil cap and that i might need a new oil cap as the oil may be comeing out from the oil cap and then dripping down, and that they may need to fully service the engine to find out the problem, and that they may need to do another oil change to drain the oil which make no sense cuz they just did the oil change, i didint notice this oil leak in the past which is why i think it may be cuz the geniuses at dufferin topped up. thanks in advance
p.s i checked my oil cap seems to be fine
Old Dec 31, 2008 | 12:21 PM
StealthTL's Avatar
Metatron
If they just did an oil change, that would explain it - removing the filter the wrong way will spew oil all down the back and side of the engine, which then takes weeks to finally drip off.
S
Old Dec 31, 2008 | 01:31 PM
Thumper3322's Avatar
Ya what stealth said. Monitor it and keep checking levels to see if it is going down to fast. Could it be your oil pan? Gasket is replaced for free under warranty.
Old Dec 31, 2008 | 01:45 PM
Trex's Avatar
yeah thanks guys i guess i will be monitoring it over the next couple days...so i guess i shouldn't be overly concerned........ or should i be? i just don't know why the retards at dufferin wanted me have the engine fully serviced and cleaned to figure such a simple thing out guess their just money hungry maybe cuz of the recession lol who knows, any ideas on any good dealerships in the brampton, mississauga area from the posts i read that erin mills mazda is pretty good any thoughts? thanks for the quick posts thumper and stealth
Old Dec 31, 2008 | 02:01 PM
StealthTL's Avatar
Metatron
Yes, seal around oil pan has no gasket - it's just some slime, and leaks are common.
The connector on the drivers side of the pan is for the level sensor, and mine has leaked and been replaced.....
S
Old Dec 31, 2008 | 05:14 PM
S
What?? seal around oil pan has no gasket? The oil pan has a gasket!
Old Dec 31, 2008 | 05:17 PM
staticlag's Avatar
The Professor
Its not really a gasket just some silicone like this http://www.permatex.com/products/Aut...sket_Maker.htm
Old Dec 31, 2008 | 05:22 PM
StealthTL's Avatar
Metatron
OK, maybe yours has a gasket, but every other Renesis doesn't.
Page 01-10-46 in the manual.
...and be "Careful not to fill the bolt holes with sealant, you'll crack the housing."
S
Gasket is RTV...and in this application it is actually better than a gasket
Likely that they made a mess and didn't clean it up
or filled it too fast and it spilled into your intake (04's)
Best thing is to clean it up and see what happens....
Old Jan 7, 2009 | 05:22 PM
Trip's Avatar
Quick question-- filling the oil too fast can result in oil getting into your intake?
EDIT: Nevermind, I used that nifty search feature nobody ever mentions to find out how that happens. That explains the oil in my own intake found yesterday. Awesome..
Old Jan 7, 2009 | 08:36 PM
Good on ya !
Old Jan 8, 2009 | 02:25 AM
long funnel ftw.
Old Jan 8, 2009 | 10:31 AM
Rotary Mike's Avatar
Registered 407 Abuser
Yeah, no gasket. I just got my pan re-siliconed at Scarboro Mazda last week.
No More "Car-Burning-To-The-Ground" smell every time I get off the highway!
Old Jan 8, 2009 | 10:44 AM
Ya it's a silicone gasket. Check the invoice it states something something gasket, that is like $150 installed/put on lol.
Good ****!
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Azki23
Jun 27, 2018 03:48 PM
poacherinthezoo
Aug 3, 2016 11:01 PM
05rx8mazda
Nov 28, 2015 09:42 AM
DG07
Sep 28, 2015 10:58 AM
